Pre 84 Trucks 1st gen pickups
carb issues 22r
Old Apr 26, 2006 | 06:14 AM
Magoo's Avatar
carb issues 22r
well i got major carb issues with a 22r.
runnin way rich(blowing black smoke),stinks like hell,runs like dirt.
i tried adjusting air/fuel mix and timing, put ngk's in it and nothing.it just wont respond.
is it rebuild time or weber or pane or 22re??
lemme know what you guys think.
Old Apr 26, 2006 | 11:26 AM
Robinhood150's Avatar
Crab issues huh? Sounds like a personal problem...
(I'll fix the title for you)
Old Apr 26, 2006 | 11:50 AM
parshal's Avatar
I just went through the same thing. My fix was to rebuild the carburetor. The idle adjustment screw only sets the mixture at idle and has no effect when running down the road.
BTW, I live in Parker, too.
Old Apr 26, 2006 | 01:01 PM
kyle_22r's Avatar
if it's running pig rich it's usually the AAP diaphragm on the side of the carb. when it goes, it spews raw gas into the vacuum lines and makes the engine blow black smoke.
Old Apr 26, 2006 | 02:21 PM
Magoo's Avatar
thanx for editing that for me i tried and couldnt.
im gonna check that aap and see if thats the issue,i pulled the carb last night just enough to drill out the idle screw plug.and there was raw fuel chillin in the intake.so that may be the culprit.
more than likely i will rebuild it or slap on a weber.
yo parshal youre in parker too? sweet.wanna help out with this???lemme know.or you got a spare carb so i can see if that one works and then i can go from there.
Old Apr 26, 2006 | 04:35 PM
Magoo's Avatar
alright kyle i just got home and checked the aap.yip fuel in there,not alot but a little wetness so theres fuel.seems like the fuel was more in the vac line than anything but nonetheless its there, so that outta be the first place to look.
thanks alot for the advice.
Old Apr 26, 2006 | 08:17 PM
Magoo's Avatar
ran it with the aap unplugged,oh man you were spot on!!!!thing runs like it should.
thanks man.cant thank you enough for saving me a carb rebuild.
shawn
Old Apr 28, 2006 | 12:09 PM
parshal's Avatar
It sounds like you already got your problem taken care of. I've now got a new one for myself. I'm rebuilding the front axle and finding broken bolts and such. I'll be working on it all weekend I'll bet.
Old Apr 30, 2006 | 08:08 PM
Magoo's Avatar
yeah that sucks i just stumbled across one too.i think i need a 22r.i cant win.
Old May 1, 2006 | 06:56 AM
parshal's Avatar
You mean another 22r carb?
Old May 1, 2006 | 09:18 AM
Magoo's Avatar
nope actual 22r.i got a slight knock.not sure if its timing chain or rod knock
dumpster84
Apr 30, 2016 06:03 AM
keithporter83
Jul 24, 2015 07:37 AM
Yota.Jay
Jul 23, 2015 08:08 PM
Tyler Cunningham
Jul 11, 2015 10:18 AM
