Pre 84 Trucks 1st gen pickups
body lift for my 1980 2wd toyota?
Old Nov 19, 2009 | 12:01 PM
MuddfreaksOffroad's Avatar
ah so they are jeep wheels?? ill start looking then um so you can raise it with the torsion bars??? lol me and my friend andrew were talkin bout that and i was like i think i can raise the fron a lil with the torsion bars he said no lol bad ass well we will see how this lift goes n if i need to ill do it lol
Old Nov 19, 2009 | 12:15 PM
SWEEEEEEEEEEEEET i just scored a set of 5! jeep wheels 5 on 4 1/2 15in wheels WITH tires for 50bucks!! hell yeah now i am set untell i get the mud tires!! hell yeah
Old Nov 19, 2009 | 06:12 PM
OK so i have a problem, i put on the 3in body lift on the cab I LOVE IT but .... my throttle linkage is ed up, ok so i lifted it set it down bulted it down and was going to drive it i got in to start it and my gas peddle would not move! at all. so i was like wtf.. i started it and everthing was ok then i pushed my pedal down n it stuck, i looked at it and what it is, is the throttle linkage bracket is it too high i unbolted it and then everything was fine, besides the idle woudlnt go down cuz it was just haning there basically. so my quesiton is how do i fix this? i looked it over and the best think i can think of is to get some spacers to bring the bracket forward towards the engine, then bring it down a lil that way its bout where it was stock????? thats the only real issue i have had other then my fan was hitting a hose clamp and stopped spinning so i over heated lol. any idea thanks sorry for the long message.
Old Nov 19, 2009 | 06:58 PM
Any ideas on the throttle bracket?? i am thinking to relocate it?
Old Nov 19, 2009 | 07:56 PM
  #25
abecedarian's Avatar
Any particular reason that a thread about a 1980 truck is in the 86-95 forum?
Old Nov 19, 2009 | 08:03 PM
  #26
Junkers88's Avatar
This is where Abe is... if you want an opinion go to where the pro lives.
Old Nov 19, 2009 | 09:58 PM
  #27
sorry thats my bad i am new didnt find a forum for 1980s ... thanks sorry too
Old Nov 19, 2009 | 10:06 PM
  #28
AZkid's Avatar
yeah you have to get a spacer, i forgot about that, i had one laying in my tool box i used, i used like a 3/4 inch aluminium spacer i had, with a longer bolt adn bam, problem solved
Old Nov 19, 2009 | 10:13 PM
  #29
yeah but see my problem is is it needs to be mounted lower?? did you ahve that problem? but yeah i am getting a spacer for them tommorrow not sure if i need to mount it lower or what....
Old Nov 19, 2009 | 10:19 PM
  #30
AZkid's Avatar
well mine was a 2inch bodylift, not a three, so you most likely need to mount it lower. did you get a shifter extension? do you have the extended tube for the gas tank?
Old Nov 19, 2009 | 10:24 PM
  #31
no shifter extension and i drove it already it is fine but do i still need it? and no i dont have the extended tube for the gas tank lol
Old Nov 19, 2009 | 10:26 PM
  #32
AZkid's Avatar
well your gonna need a longer tube for the gas tank, so dont lift the bed til you get it,
and i hate having the 2 inch body lift and that short stick, the shifter extender just makes it so the stick is the height it should be.
Old Nov 19, 2009 | 10:27 PM
  #33
AZkid's Avatar
look how short the shifter was:
Old Nov 19, 2009 | 10:30 PM
  #34
oh i dont mind it shorter its alright, and where do i get that extender???? lol
  #35
AZkid's Avatar
the shifter extender or gas tank tube?
Old Nov 19, 2009 | 10:33 PM
  #36
yes. where would i find that and how much would it cost do you think? or would i have to make it basically??
Old Nov 19, 2009 | 10:34 PM
  #37
opps gas tank extension thingy
Old Nov 19, 2009 | 10:37 PM
  #38
AZkid's Avatar
do you have a second mode of transportation?
Old Nov 19, 2009 | 10:38 PM
  #39
AZkid's Avatar
mine came in my kit, just take it off and run it down to ace hardware or whatever local place around you that has tubing at various lengths and pick some up and hose clamp it on there
Old Nov 19, 2009 | 10:42 PM
  #40
OH NICE and yes i have a car lol ... ill do that tommorrow then so what kinda metal/plastic or rubber tube should i get??? and how do i throw it all together?? sorry if im asking stupid quesitons lol i normally dont do 2wd work but its my truck n i want it big n better hahaha Im hopefully getting a 4x4 soon
