Pre 84 Trucks 1st gen pickups
Blow by
Old Mar 3, 2013 | 08:27 PM
Baca17's Avatar
Blow by
I have a 1983 Toyota pickup 2wd. I'm having a problem with oil entering into my air filter. I replaced the PVC valve but still happening. What's next on the list to resolve my problem ? Thank a bunch !
Old Mar 4, 2013 | 06:02 AM
Bingle's Avatar
Pull the valve cover and make sure someone didn't remove the plate inside. The pcv "port" should not be visable on the inside of the valve cover withouut removing the plate.
Old Mar 4, 2013 | 10:39 AM
on1wheel01's Avatar
Yea for sure should have the plate. I just took mine apart to powder coat it. Had to order the better gasket kit so I could have the inner plate gasket. Also I figure replace the valve while I'm.in there
Old Mar 4, 2013 | 04:40 PM
Baca17's Avatar
Well when I first purchased the truck I did not have this problem. Could this plate have came off on its own ?
Old Mar 4, 2013 | 07:02 PM
on1wheel01's Avatar
This is what it looks like without it
This is the plate you should have
You can see how it lines up
Old Mar 4, 2013 | 07:10 PM
Baca17's Avatar
Thank for the visual. Appreciate it. I'll pull it this weekend.
Old Mar 4, 2013 | 07:27 PM
Toyota~Boy's Avatar
If its not that then your blow by could be cause by the piston rings which requires rebuilding to fix.
Old Mar 4, 2013 | 08:08 PM
Baca17's Avatar
I've seen rebuild kits with pistons rings and all of that. Is that worth the money ?
Old Mar 5, 2013 | 06:01 AM
Bingle's Avatar
I would check my compression before I jump to any conclusions. Try to KNOW what the problem is before throwing parts at it. Sometimes you have to go with "most likely", but you should do some diagnostics to figure out what's wrong.
Old Mar 5, 2013 | 06:10 AM
Baca17's Avatar
That is what I am trying to do. The oil in the air filter is just annoying and not good for the truck. I want to fix this ASAP bc I am spilling oil everywhere I go.
RyanJ989
11
Apr 7, 2021 09:41 AM
puddlepirate
Jul 30, 2016 06:29 PM
4banginRunner
Nov 13, 2015 05:23 AM
bryan34w
12
Sep 30, 2015 02:50 PM
Scotttekoch
Sep 28, 2015 10:30 PM
