Pre 84 Trucks 1st gen pickups
blow by
Old Oct 4, 2012 | 04:45 PM
85toy's Avatar
blow by
hey people havnt made a thread on here for awhile.
I have a 1979 that i just recently got, its got a 20r and im worried about the blow by.
it has a lot of oil coming out of the hose that goes from the top of the valve cover to the top of the air filter lid. something i think is odd though is if i take off the oil cap(not running) the cap is all dry on the inside i would think it would be wet with oil( all my other toyotas have been) so what do you guys think the problem is?
I could take pics if anyone thinks that would help but i think i explained it well enough.
Old Oct 4, 2012 | 06:52 PM
kawazx636's Avatar
Seems a little strange to me that your oil cap is dry but the breather hose is pulling oil . That breather hose does have a slight vacuum going through it, but shouldn't be enough to pull oil.
Has the baffle on the valve cover been removed? Is the PCV valve clogged?
You can check blow-by by taking off the oil can and flipping over on the oil filler hole. It should be able to sit there on its own and not "levitate" from the pressure in the valve cover
Old Oct 4, 2012 | 07:04 PM
85toy's Avatar
thanks ill check the pcv and do that cap test tomorrow.
Old Oct 5, 2012 | 01:48 PM
85toy's Avatar
ok PCV valve is working just fine. the cap jumped around a little bit but it didnt try to levitate.
Old Oct 6, 2012 | 05:31 PM
85toy's Avatar
145 views and 1 reply
Old Oct 8, 2012 | 08:26 AM
kawazx636's Avatar
Seems fishy... Have you taken the valve cover off yet??
Old Oct 8, 2012 | 03:47 PM
85toy's Avatar
nope im focused on fixing my exhaust right now, big leak at the manifold.
Old Oct 9, 2012 | 08:30 AM
kawazx636's Avatar
I would make sure that the baffle in the valve cover is still in there.
RyanJ989
11
Apr 7, 2021 09:41 AM
puddlepirate
Jul 30, 2016 06:29 PM
4banginRunner
Nov 13, 2015 05:23 AM
bryan34w
12
Sep 30, 2015 02:50 PM
Scotttekoch
Sep 28, 2015 10:30 PM
