Pre 84 Trucks 1st gen pickups
Back firing?
Old Nov 8, 2006 | 07:57 PM
Sonofmayhem's Avatar
Back firing?
what causes this? huh? i only hear it when im decelerating and braking.
Thanks
Old Nov 8, 2006 | 08:05 PM
myyota's Avatar
From what i have been told, back firing is caused by unburned fuel in the exhaust igniting. when was the last time you did a complete tune up on your truck and checked the timing ?, that might help or fix the problem your having.
Old Nov 8, 2006 | 08:30 PM
4runnermt's Avatar
I agree it may be a timing issue.
Old Nov 9, 2006 | 02:08 PM
i just did everything except the wires, so ill do timing then some spark plug wires. thanks
ANyone else?
Old Nov 10, 2006 | 12:17 AM
84sr5yoty's Avatar
Incorrect timing and a very lean fuel mixture causes backfiring. Check for vacuum leaks and vacuum test the brake booster to make sure the internal diaphragm hasn't gone bad.
Old Nov 11, 2006 | 02:35 PM
really, well i need to time it, how do i go about this? ill have the light, but im just not sure where to point it, what to look for, and what to adjust. thanks
Old Nov 11, 2006 | 03:17 PM
crackerjack's Avatar
I was cleaning my intake and read something about the dash pot a kinda shock absorber for the throttle cable will cause backfire if not adjusted and doesn't a leak in the exhaust cause backfire?
Old Nov 23, 2006 | 02:17 PM
toyota_mdt_tech's Avatar
Thanks
Air entering the exhaust and burning unburnt fuel. DO you have an air pump or an air suction system? If so, the diverter valve should direct the air intot he air cleaner on decel, yours is probabvly stuck blowing it into the exhaust. The extra air makes the fuel burn, and also extra air can coem from just a plain old fashioned exhaust leak.
Doug4320
Mar 24, 2018 10:11 PM
Poncho0206
Jul 10, 2015 06:21 PM
87blyota
Jul 10, 2015 04:31 AM
Kluch8651
Jul 9, 2015 10:39 AM
elwood73
Jul 5, 2015 07:07 AM
