83 toyota pickup with no heat
I have a 1980 toyota 4x4 that I switched the motor out and put the same 22R motor in but out of a 1983 into my 1980 truck. Since the swap, I have no heat but the fan works so it blows out cold. I have some overheating problems but no leaks are appearing. I replaced the thermostat and the water pump. Any ideas what it could be? Could it be the radiator or the hoses? My 1980 motor only had 1 hose for the heater and the 1983 motor had 2 hoses to the heater. I just t-d them together could that be a problem?
Did you properly bleed the system....by leaving the radiator cap off and turning the heat on in the truck and continually filling the radiator until no air bubbles are coming out. If you have air trapped in the system, the coolant will not flow correctly, thus having no heat in the driver's compartment, and overheating. Just a thought
The pretty much narrows it down to either the fan clutch and/or radiator.
Heater core needs an inlet and outlet line to allow the hot coolant from the engine to flow through it. When you say to T'd the lines together, how did you do that? On my '85, inlet hose is off the heater valve at the upper left corner and the outlet hose is about in the center of the picture below:
6th Gear
19
Dec 10, 2019 07:31 AM
Aleeex_u
Jun 5, 2016 06:52 PM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
