Pre 84 Trucks 1st gen pickups
82 fuel pump output too low?
Old Dec 29, 2023 | 02:47 PM
Jimowen's Avatar
I've measured the output PSI at just under 4psi which is in the correct range of 2.1 - 4.3.
The fuel output, though, was 13 ounces in 30 seconds when specs call for 16 ounces. Does this difference of 3 ounces suggest the need to replace the pump?
I've changed the fuel filter. Even drained the fuel tank looking for any reason to flush it. Nothing. Clean.
Old Jan 2, 2024 | 11:54 AM
Jimowen's Avatar
New fuel pump from NAPA.
Old fuel pump put out 13 fluid ounces of fuel per 30 seconds.
New NAPA fuel pump is rated at 21 fluid ounces per 30 seconds.
Carb problems? Check that old fuel pump first.
Old Jan 8, 2024 | 06:27 AM
13Swords's Avatar
5 Year Member
Most fuel pumps have a Gallon Per Hour (GPH) rating. All the pumps I checked on Rock Auto have a 20 GPH rating. So let's do the math. 20 GPH divided by 60 minutes equals. 0.33 gallons per minute. Since you only measured in half a minute (30 seconds), divide that by 2 (in half) and you get 0.166 gallons per minute. To get ounces, 128 ounces (how many ounces in a gallon) divided by 0.166 equals 21.248 ounces.
13 ounces in 30 seconds? Sound like a tired pump to me.
Old Jan 9, 2024 | 06:11 AM
mi_guy616's Avatar
I'd watch where I bought it. I just had a RockAuto pump go out in less than a year. I can't remember the brand on it. I'm just grateful it's not like a modern truck so I didn't need to drop the gas tank.
greyheadedguy
May 9, 2019 09:12 PM
Cwolfe
Sep 12, 2015 12:23 PM
penhal-prerunner
Jan 23, 2013 01:29 PM
summerstud_02
Feb 20, 2008 11:24 AM
keithguts
Mar 15, 2007 07:16 AM
