Pre 84 Trucks 1st gen pickups
‘82 4x4, GM LV3 4.3l Engine Swap
Old Nov 23, 2020 | 02:40 PM
  #121
Trueblue93's Avatar
Ok....so I didn't want to waste the opportunity while the bed was off to paint the rear frame section. After doing some reading and YouTubing I decided to hit it with heavy duty oven cleaner and let it sit for a day. Then you hit it with a degreaser on top of that. I used Simple Green. I let it sit on there for about an hour and then you power wash it all off. It works amazing well. It took it down to the bare metal in most places. Use a respirator though. That oven cleaner is very caustic. I repeated this process one more time for good measure. My next step was to wipe it all down with wax and grease remover to get it ready for paint. I used Eastwood Platinum Rust Encapsulator. Overkill probably, but that's par for the course. After 5 hours of dry time I put a coat of Eastwood Extreme Chassis Black. It is really thin stuff. A mini rolller can get about 90% of everything. I used a brush for the cracks and crannies. If I think it needs another coat tomorrow I'll do it again. Now on to sanding the cab! My least favorite part. The Encapsulator is silver. I added a couple more pics of the bed.
Old Dec 1, 2020 | 10:35 AM
  #122
russman206b's Avatar
where did you get tent set up and wheels and hub caps looks awesome
nickpohlaandp
Oct 9, 2016 05:23 PM
Unbrakeable
3.4 Swaps
46
Jul 21, 2014 04:34 AM
chukarhunt
All Other Toyota Swaps
Sep 10, 2013 05:40 AM
MistaMota
Sep 8, 2012 07:56 AM
poomba
9
Jan 9, 2004 05:34 PM
