Pre 84 Trucks 1st gen pickups
81 manual transmission replacement
Old Dec 10, 2018 | 06:03 PM
cuaco-ortiz's Avatar
hey guys, need a bit of help here.
my current tranny is a five speed, and pops out of first, that's annoying and also makes a horrible noise if i don't push it and keep pushing it until it engages.
it also runs rough in 3rd gear and vibrates a bit at around 2k rpms.
What i would like to know is if i can change the tranny with a newer 5 speed? like one from and 89 or even a 94?, also can i use the same t-case?
maybe if i can get the tranny and t-case complete from a newer truck?
will they fit into the 22R
please any info you can give me will be great.
thanks...
Old Dec 11, 2018 | 05:52 AM
dropzone's Avatar
Fossilized
yes you can do that with some changes
Stock L Series transmissions (L-43 and L-45 are 4 speeds, L50 & L52 are 5 speeds are 21 inches long)
Later transmissions G series, W Series etc are 25 inches long so you would need to move your cross member back 4" for the T/C mount, lengthen your front Driveshaft and shorten your rear driveshaft the correct amounts if swapping to a later model trans
jacobtodd123
Feb 25, 2015 07:53 PM
jeremyt
3.4 Swaps
14
Mar 17, 2009 06:13 PM
hale
Jun 11, 2004 05:45 AM
Roadrunner
18
Jan 6, 2004 06:25 PM
Roadrunner
Apr 11, 2003 09:47 AM
