81 2wd tranny in 82 4wd
I just got a 81 diesel 1L and 2wd tranny. The bell housing on the diesel appears to be the same bolt pattern but the diameter is an inch or two larger so a straight swap is not possible compared along side a 82-83 4wd transmission the transfer case will bolt right in behind the shifter. The cover on top also has to be swapped.Length of transmission is the same from mount to front edge of bell housing.
The gearing should be the same. The extra fuel milage is due to the diesel motors efficiency
Pedalpwr27
Aug 13, 2015 06:37 AM
landrunner
Aug 5, 2015 09:18 PM
Iceman4193
Jul 15, 2015 04:48 PM
