Pre 84 Trucks 1st gen pickups
5 speed?
Old Jan 8, 2009 | 06:44 PM
foxracing31702's Avatar
5 speed?
i have to get a new clutch but i noticed a guy locally is selling a 5spd from a 79 for $100. i was wondeing if itd be worth getting and replacing my 4spd. ill be driving the truck on the hwy and everything also
Old Jan 8, 2009 | 07:17 PM
4banginRunner's Avatar
I dont remember Toyota putting a 5spd in a 4x4 79, thought it started with the 22R in 81
Old Jan 8, 2009 | 07:45 PM
i didnt think they made them back then either but thats what the ad says....maybe hes counting reverse to? or maybe the 5spd was in the truck when he got it.....but im just wondering if its worth the few extra bucks to get the extra gear.
Old Jan 8, 2009 | 07:50 PM
With the model of the 5spd aside, swapping out your 4spd will make a world of difference. The L43s were carry over trannies from the 2wd's/cars, with an alum. adapter to the t-case. 1st gear is 3.67, compared to most others with a 3.93 first.
Old Jan 8, 2009 | 07:54 PM
do i have to get the adapter or is it just a direct swap?
Old Jan 8, 2009 | 08:06 PM
also you said l43, so im assuming theres different models. are there certian ones that are better/worse. any easyer or harder to change out?
Old Jan 9, 2009 | 02:59 AM
any 79-95 4cyl trans will bolt up, no adapter
79-83 (will bolt up with not modification to x-member on a 1st gen)
L43 4 speed 79 - 80 3.67
L45 4 speed 81 - 82 3.93
L50 5 speed 81 - 82 3.93
L52 5 speed 83 3.93 <---Best bet for no mods to x-member
84-95 (will required custom x-member mount due to longer length)
G52 & G54 5 speed 84 - 88 (Carb) 3.93
W56 5 speed 85 - 95 (EFI) 3.95 Manual Hub Equipped Vehicles 89 and up Have W56, 89 and up ADD vehicles have G58.
85 4Runner w/EFI is W56A
W56 is most common and the stronger of the 4cyl trannies
Old Jan 9, 2009 | 05:14 AM
dang, theres alot of different years and models. thanks though!
Old Jan 9, 2009 | 05:36 PM
would a 5spd from a celica work?
izzmee
Aug 17, 2015 10:20 AM
91yotapup
Aug 17, 2015 09:40 AM
129Creepin
Aug 5, 2015 10:12 PM
kyletbert
Jul 17, 2015 11:39 AM
wilbertd
Jul 6, 2015 07:39 AM
