4wd indicator light
switch should have two studs on it and wires slide over round studs. will take picture for you in morning. but should have 2 wires. i have both setups will crawl under and check them out when sun comes up..
i have the opposite problem here where the harness at the transfer case was disconnected, plugged it back in - now the light stays on all the time and won't go off, is there a relay as part of this system that could be the problem - the transfer case was supposedly rebuilt too so that could have something to do with it...
Marc
10
Dec 28, 2015 01:08 PM
