Pre 84 Trucks 1st gen pickups
22R oil pump question
Old May 13, 2009 | 11:22 AM
Csull's Avatar
I am in the process of redoing my timing chain on my 81 22r, every thing is going pretty straight forward with the help of other posts and the search function. but for the life of me i cant find any info on the gears inside the oil pump. and where the arrows are suppose to line up to when re assembling
my question is, "where do the 2 arrows(facing away from crankshaft) on the oil pump gears line up with?"
I can post pictures if it would help.
Old May 13, 2009 | 03:14 PM
slacker's Avatar
they dont .
they are just a referance for the "top side" ...
so just install them top side up and pack them with primming grease (I use lithum white grease)
you do know about the top housing bolt ... right ?
Old May 13, 2009 | 04:00 PM
Csull's Avatar
top housing bolt??
top side meaning they face the engine block?.. because that's the only way the crank pulley will go on
Old May 13, 2009 | 05:32 PM
slacker's Avatar
Originally Posted by Csull
top housing bolt??
it dosent matter ... as long as both "arrows " are on the same side ... (front or back)
as far as the bolt I mentioned ...
the top bolt on the oil pump .. is a "threw bolt" as seen in this pic
if the wrong bolt is installed .. it will contact the tensioner and interfere with it's performance ..
make sure you put the correct bolt back in this place ..
Old May 13, 2009 | 05:50 PM
Csull's Avatar
AH gotcha, Thanks a lot for the help
Old May 13, 2009 | 08:40 PM
slacker's Avatar
your welcome ..
dont forget to put some sealant on that bolt as well ... it has a tendancy to leak .
bigjstang
Jun 2, 2025 03:56 PM
Sep 4, 2015 09:27 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
87blyota
Jul 10, 2015 04:31 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
