Pre 84 Trucks 1st gen pickups
22r fresh rebuild slow to build oil pressure
Old Apr 2, 2011 | 09:32 AM
griffinleather's Avatar
Right, the timing cover houses the oil pump and water pump. Did you replace it?
Old Apr 2, 2011 | 12:55 PM
AZprospecter's Avatar
i have a new timing cover and oil pump and the play on the face of the gears is the only thing left that i can find that could cause the problems im having with it. it just doesnt seem right to me that both being brand new parts that it would be like that, i would think that the oil pump gears would have a pretty tight clearance against the timing cover.
Old Apr 2, 2011 | 07:05 PM
peow130's Avatar
Pull the cap off the top of the oil pump, pack it with vaseline, start your truck..
Theoretically this should prime your oil pump, and make your oil pressure go up.
Worth a shot.
Old Apr 3, 2011 | 08:17 PM
i primed the pump every time i put it on and it gets instant oil pressure the first time i start it then after it sits for half an hour its back to the same problem with it taking forever to get any pressure at all
Old Apr 4, 2011 | 08:23 AM
  #25
Robs Toynado's Avatar
Have you had any luck yet? My 20r did this untill a drag racing friend asked me what kind of filter i was running. I was using fram filter (thought they were the best). He told me i should try Wix filter. So i took his advice and found out it gets oil pressure faster. I guess he says its the way thier made. I dont know if this could be a problem but it may. Hope this helps!
Old Apr 5, 2011 | 07:47 PM
  #26
today i took the old pump and sanded down the housing to bring down the excess clearance on the gears. it did seem to help alot now that it fits tight enough that the gears wont move back and forth. hopefully i can run around town and find a better brand of filter and see if that makes it any better.
bigjstang
Jun 2, 2025 03:56 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Colington
Mar 8, 2020 09:51 AM
87blyota
Jul 10, 2015 04:31 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
