Pre 84 Trucks 1st gen pickups
1980 Truck power "pulsing"
Old Jan 24, 2010 | 01:41 AM
Stjamesgate's Avatar
Hi,
My 1980 Truck, rebuilt 22R, has a new (less than 500 miles) alternator, new voltage regulator, distributor, and battery. When driving through some rough terrain, a loud clicking began from under the passenger side dash. Then I noticed the gauge stack (oil pressure, voltimeter, and temperature) starting "pulsing" in concert with the click as did the dash lights. I figured it was a loose connection and wet (near ocean). Dried the truck and let idle and the pulsing stopped for a while so I parked it for a month. Went back to let the engine warm and the pulsing continued. This time I noted the new battery was bubbling and dripping acid (although it is a battery that warns to not open -- Oreilly battery). Possibly the voltage regulator gave up the ghost, or? I'm not sure as I re-ran the wiring, etc, to make sure all connected but am at a loss. I'm in the middle of nowhere with no mechanics around. Penny for your thoughts?
(PS. I had aftermarket a/c added and the clicking is coming from around where the a/c is at. Professionally installed a/c).
Old Jan 24, 2010 | 12:23 PM
cdg's Avatar
cdg
Turn off all the lights at night and look for sparks. Sounds like something is short circuiting. I would also get a load tester and see how that alternator is doing. Could be overcharging. When you parked it for that month did the battery drain?
Old Jan 24, 2010 | 10:29 PM
Last year, I had parked the vehicle for about three months with everything connected. When I went to start it, it acted as if the battery was dead. However, I replaced the battery and still heard a "click" like the starter wasn't getting enough power. Ichecked the connections to the starter, thumped it, and it started no problemts. Didn't drive it much until the weekend outing. When arked for hte month, I simply disconnected the battery. Reconnected it, started the truck and then noticed the pulsing was back. Maybe an issue with the starter? That, too, is new. Hmmm.
Old Jan 24, 2010 | 10:46 PM
toyotabull's Avatar
start pulling fuses with it running and see if you can stop the clicking. check the wiring in the floorboard. Let us know what you find and welcome to yotatech. Where are you from?
Old Jan 26, 2010 | 07:24 PM
toyboy79's Avatar
bad idea
Old Jan 30, 2010 | 03:49 AM
Thanks for all the help! Why is pulling the fuses a bad idea? I'm making the plans to go and work on the truck today but don't want to do anything silly. And currently i'm stuck in africa; hence the inaccessibility of shops.
Old Jan 30, 2010 | 04:22 AM
toyboy79's Avatar
by pulling fueses it will backfead to the electronics and you can kiss your electronics good by
Old Jan 30, 2010 | 07:53 AM
rottenagenda's Avatar
voltage regulator. battery bubbling case of a over chargeing
lledwod
Sep 6, 2016 07:33 AM
rbravo1
Jun 29, 2015 01:34 PM
Crazy_Guy97
12
Jun 24, 2015 04:02 PM
nyk08trx
Jun 18, 2015 09:01 PM
