Pre 84 Trucks 1st gen pickups
1980 toyota hazards work but no blinkers?
Old Apr 1, 2010 | 10:56 AM
TrevanO's Avatar
Exclamation 1980 toyota hazards work but no blinkers?
Basically my 1980 toyota blinkers work with the hazards on but when they are off and i flip the blinker switch i have to manually flip it up and down to get them to work. is there a fuse of some sort? and where is it located.
I'd appreciate the help
Old Apr 1, 2010 | 03:30 PM
slacker's Avatar
have actually walked aroung to make sure the lamps/bulbs are lighting and working/flashing .. ?
Old Apr 1, 2010 | 06:39 PM
TrevanO's Avatar
yes i did a walk around, my front blinkers dont work, they arnt wired. but my rears are wired. they blink with the hazards on but without the hazards on when i flip the blinker left or right it blinks once, if i flip it to the left 2 times it will blink twice. Basically i'm just tired of manuelly using my blinkers and looking for a solution.
Old Apr 2, 2010 | 06:38 AM
slacker's Avatar
this is your problem .
the circut is not complete with out the fronts
Old Apr 4, 2010 | 12:44 PM
redrider218's Avatar
i have a similar problem but my blinkers will only blink with the hazards on. They will not even blink manually. Ive checked the bulbs and all are good.
Old Apr 4, 2010 | 08:57 PM
TrevanO's Avatar
redrider it sounds like your having a bigger problem then me.
So do i need to replace the whole unit?
Old Apr 4, 2010 | 09:00 PM
Kiroshu's Avatar
What do you mean "they aren't wired, But my rears are wired"? Sounds to me like that combo switch is bad.
Old Apr 9, 2010 | 10:06 PM
TrevanO's Avatar
where is the combo switch located?? lol
Old Apr 15, 2010 | 08:28 PM
79TONKATruck's Avatar
I had the same prob with mine and i took apart the steering colum and cleaned the contacts at the end of the blinker switch and every thing around it and they worked fine
lledwod
Sep 6, 2016 07:33 AM
Crazy_Guy97
12
Jun 24, 2015 04:02 PM
gog1968
Jun 22, 2015 05:55 AM
