Pre 84 Trucks 1st gen pickups
1978 toyota20r 4 cyl
Old Apr 21, 2011 | 09:04 PM
tat21212's Avatar
not sure where to put this. have a 1978 toyotatruck 20 r 4 cyl. the clutch seems to have gone still have plenty of pedal as allways the gear shifter acts like its not connected just moves all around but doesnt seem to go into any gear. any suggestions? thank you
Old May 5, 2011 | 10:24 PM
the_supernerd's Avatar
You most likely have an L series transmission, which has a bunch of linkage on the side of it. Check that all of the linkage is still connected. It sounds like something may have broken loose.
Old May 8, 2011 | 07:44 PM
'83Toy's Avatar
is it a 4 or 5 speed? the above response is correct in that you most likely have an L series, which is top shift. When i purchased mine the shifter slopped, and flopped all over, but it shifted.
the excessive play and give could be due to the shift lever ball seat. marlin sells an upgraded, machined, urethane version. im not tranny expert, but if its not shifting at all, my guess would be a broken shift fork..
Old May 9, 2011 | 06:15 AM
83's Avatar
83
L4x= side shift. L5x= top shift.
Bourbonblues
Dec 15, 2017 05:43 PM
alexcarey
Oct 14, 2015 06:05 PM
Regency
Sep 24, 2015 07:23 PM
PBRaddict#1
Sep 22, 2015 07:50 AM
langry345
Sep 14, 2015 03:36 PM
