Pre 84 Trucks 1st gen pickups
1978 Toyota pickup. I need AC!!!
Old Jun 2, 2006 | 07:19 PM
mackdss's Avatar
Got my 78 running great. All that is left is to paint the beast. I am sure it is possible but how much of a hassle would it be to install AC in the truck. It gets really hot in this thing. I have seen condensors on Ebay for cheap but I know there are many other parts needed to be installed. Would anybody know of a website that sells a kit or parts needed. Is it a waste of money and time to do it. Thanks for any info, Mack
Old Jun 3, 2006 | 01:29 AM
kyle_22r's Avatar
usually ackits.com has conversion kits for everything, but not that particular truck. i KNOW that A/C was available in '78. you may get lucky and find a setup on ebay, but you can always scrounge the junkyards. i believe the cab and vent system from '79-83 trucks is very similar, you may be able to use parts from those, as they are easier to come by.
Old Jun 3, 2006 | 07:02 AM
mackdss's Avatar
thanks Kyle. I checked ackits.com and they have parts for the 78 but no kit. They have a kit for a 79 pickup. How much different was the 79 from the 78. I thought they were pretty much the same truck. My truck was built in i think september of 78. I emailed ackits with the same question. Mack
Old Jun 3, 2006 | 03:24 PM
slacker's Avatar
anything after July (month 7) production , is considered =NEXT year production .....
meaning your truck 7809 is a 79 vehicle.
Old Jun 4, 2006 | 10:59 AM
kyle_22r's Avatar
easy way to tell if it's a "78" or "79" -- if it has 4 headlights, it's a 78, 2 and it's a '79.
Old Jun 4, 2006 | 03:19 PM
mackdss's Avatar
it has 4 headlights. so is the HVAC system totally different between the two??
Old Jun 4, 2006 | 05:27 PM
kyle_22r's Avatar
i'd think that the main difference is in the ducts. both trucks have the same type of side vents(the ones with the little ball), that is what the A/C air comes out of, on a non A/C truck they just flow fresh outside air. i'd imagine the compressor setup would be nearly identical as well.
i'm not 100% sure here, but i think that's where i'd start.
Old Jun 4, 2006 | 05:32 PM
mackdss's Avatar
Thanks Kyle. I'll wait to see what ackits has to say about the difference. It is nearly impossible to find a junked 78 with ac I could pull out of. That would be the easy way. But doubt I could locate one. thanks again.
Old Jun 9, 2006 | 02:13 PM
Phssthpok's Avatar
the A/C on my 77 was a factory 'retrofit' under-dash unit....no cold air from the 'ball' vents.
Too bad you didn't post this a bout 8 months ago when I yarded it all out... I woulda just GIVEN you the stuff!
Old Jun 21, 2006 | 01:21 PM
mackdss's Avatar
After some time ackits.com replied and said that their 79 kit would not work. But they gave no reason to what the difference is. I have looked on the internet to check what the differences are but can't find anything. If anybody knows let me know.
also would anybody know if anybody sells a universal kit. the retro kit Phssthpok talked about would work with me. I hate the heat!!
MO transplant
Apr 23, 2023 11:58 AM
Regency
20
Jan 3, 2020 07:43 PM
Sep 4, 2015 09:27 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
