stock original 22RE parts
Old Apr 28, 2008 | 06:19 PM
fast68's Avatar
so im gonna list some of the parts i snagged off my 88 22RE 145k miles truck before i hauled it to the shredder last week just for the heck of it even though i know i am wasting my time and no one will want any things from these engines, but i apparently like to type so much that im going ot anyways haha:
MAF sensor assembly entire top of air box, functioned fine,
distributor, coil, ignitor, wires, cap, everything, ran perfect
all four fuel injector wiring harness clip pigtails with a few inches of the wires
entire TB unit with all sensors and everything intact, however the TPS is needing replaced, otherwise fine and ran great regardless
air intake ducting tubes large one and small one both across radiator support from the MAF to the TB unit; good shape no crack or break anywhere
two electric vacuum switches on the valve cover for with 4 speed auto trans; blue one and red one
power steering and belt idler tension adjustment pulley assembly bracket unit
radiator for with auto trans, always kept normal temps and normal system pressure, no leaks anywhere
fan shroud for same, not cracked
OEM fuel pump and hanger assembly; all intact complete nice; for 2wd pickups
ECM/ECU for 22RE and A43D 4 speed auto overdrive trans 1988
original heater core shut off valve assembly from top of firewall under hood works good; stock metal one
and some other parts i dont remember
pics and numbers available
make offer mailed from 62656
i have little spare time i am wlasy working or at work,
i sleep eat work over and over constantly
so email me, or i dont know
thanks
voiddweller
19
May 2, 2016 09:10 PM
noahstancik
Jul 10, 2015 11:18 AM
CJ94yota
Jul 3, 2015 10:14 PM
streetuner15
Jun 18, 2015 10:59 PM
