Engines - Transmissions Place above type items here
FS[NorAtl]: LCE W56-C Short Shifter Kit with shifter and base
Old 06-07-2016, 11:36 PM
TransAmBandit's Avatar
Up for sale is the short shifter kit I bought for my truck. Before anyone says anything about the price, my price is a little higher because I am including the shifter and base from my transmission with the kit already assembled.
Yes you can buy the kit new for $139. But you can also buy the one I have and keep your stock stuff for easy swap in and out.
I bought the kit for the transmission I swapped into my truck. Shortly after getting the truck running. I found out the transmission was junk. And ended up swapping to a cheap g54 I found locally. So the kit is of no use to me. It has ZERO miles on it.
It will come with the two shifters, base plate, the seat bushings installed, the six extended bolts. I bought a new retainer ring for the tcase shifter which is installed. The shift extension set screws are loctite and staked already. Has some RTV on the base where I installed it.
Looking for $150 plus shipping. Shipping shouldn't be much in the 48. I'll pack it as close as I can.
Attached Thumbnails LCE W56-C Short Shifter Kit with shifter and base-image.jpeg
Old 07-13-2016, 11:25 PM
Bump
Msglength
Old 12-05-2016, 11:06 PM
Gerard's Avatar
Hi just wondering if you still have this for sale
[QUOTE=TransAmBandit;52323788]Up for sale is the short shifter kit I bought for my truck. Before anyone says anything about the price, my price is a little higher because I am including the shifter and base from my transmission with the kit already assembled.
Old 01-07-2017, 05:28 AM
Bump, still have this shifter setup. If you're seriously interested, please PM me. Thank you!
Old 03-29-2018, 08:37 AM
nashulee's Avatar
I know its been over a year, but worth asking, do you still have this set up?
Old 11-17-2019, 04:47 PM
bump. Still sitting in a box in my garage. I never really made a solid attempt to sell it. Have no use for it.
Old 10-08-2020, 02:28 PM
tlmollette's Avatar
Hello, would you happen to still have this? If not, where did you buy it from? I have been having horrible luck finding one.
Thanks
Tracy
Old 04-12-2022, 02:54 PM
myproject4x4-2gonow1's Avatar
W56C shifter
Hi! like to know if you have the shifter available ill meet your price. thank you
Old 04-12-2022, 03:08 PM
WANTED to buy (2) W56C forward shifters complete with base plate
Jcrawl94
04-12-2017 10:55 AM
ryan13
Engine Swaps
03-16-2016 06:49 AM
80seriesftw
03-05-2016 10:08 PM
Chris Parker
02-14-2016 01:15 AM
BUDD
02-08-2016 12:53 AM
Quick Reply: FS[NorAtl]: LCE W56-C Short Shifter Kit with shifter and base
