Tool Time Discussions here pertain to the use of tools you use while fabbing and wrenching in the garage
PSI To Ft lbs
Old Jan 24, 2010 | 11:50 AM
ROCK HOUND's Avatar
PSI To Ft lbs
Here is a real conundrum.
Lets say i am finishing a job on my truck that required me to remove my wheels. I have a pneumatic impact wrench in my hand, attached to a 155 gallon tank with a compressor on top. How high should i set the PSI on the compressor to torque the lug nuts on? (assuming i dont have a torque wrench to check)
At first i thought they would be equal, but the more i think about it the less sense it makes. PSI is a rating on pressure and Ft lbf is a measure of torque or force applied to a pivot point, so i dont think that you can convert from one to the other. But that can be right, shops use impact wrenches all the time and i doubt that even the best shops check EVERY.....SINGLE....bolt?
Anyways i'm just bored here at work and thought that someone here has got to understand this...thx
Old Jan 24, 2010 | 12:03 PM
buckz6319's Avatar
google>>>>>
Old Jan 24, 2010 | 12:30 PM
RobD's Avatar
No, a lot of shops use torque bars or torque sticks to save time.
http://www.sjdiscounttools.com/accat4.html
Old Jan 24, 2010 | 12:35 PM
Tbeck792's Avatar
The impact wrench should have a chart. It varies from wrench to wrench.
Old Jan 24, 2010 | 12:53 PM
gary96360's Avatar
shops usually just use an impact to tighten the bolts and dont check the torque of the nuts, for tires ive noticed that most of the shops used torque wrenches. personally i never use a torque wrench for wheels i just tighten them around 100 ft lbs
Old Jan 25, 2010 | 12:23 AM
wyoming9's Avatar
Red face
I run 90 psi on my impact a few different kinds . With never seize I snug them up I have never broke a stud or had a wheel come loose .
I have never torqued a lug nut But I also torque the wheel bearing lock nut.
Torque wrenches are cheap How can you not have one???
Old Jan 25, 2010 | 01:50 AM
vital22re's Avatar
totally a bro
i've always gone by feel on my rigs and never had issues. But when i worked at a shop a ran on the lug nuts with a 40lbs impact torque stick. Then torqued with a torque wrench to factory spec and with a paint pen initialed the back of the tire just in case.
Old Jan 25, 2010 | 03:24 AM
ROCK HOUND's Avatar
Yeah i tried google and that didnt produce good results. I just thought i would toss a new thread up and see what people thought, not really all that important. I own 2 torque wrenches and only use them on things that would need it, such as engine and suspension compents. I was just simplify the senario, usually for lug nuts i use around 90-100psi which has worked so far.
Old Jan 25, 2010 | 04:08 AM
turyota90's Avatar
air tools are made to run at about 90 psi. if you're worried i would use the torque wrench. don't over tighten them and you certainly don't want to under tighten them. should be around 80-90 ft lbs. better to be sure. you said you only use them when it's something that really needs it. tires are important to keep on the car
Old Jan 25, 2010 | 08:08 AM
buckz6319's Avatar
here is something I found on google....maybe it will help
Killowatts to Horsepower:
HP --> KW:
* Horsepower x 0.746 = KW's
eg 200hp x 0.746 = 149.2KW's
KW --> HP:
* KW x 1.34 = Horsepower
eg 149.2kw x 1.34 = 200hp
Newton metre's of torque to Pounds per feet
Nm --> lb
* Nm x 0.74 = lb ft
eg. 143nm x 0.74 = 105.80lb ft
lb --> Nm
* lb ft x 1.36 = Nm
eg. 105.80lb ft x 1.36 = 143nm>
Kilopascal to PSI (pounds per square inch)
kPa --> PSI
* kPa x 0.145 = psi
eg. 100kPa x 0.145 = 14.5psi
PSI --> kPa
* PSI x 6.98 = kPa
eg. 150psi x 6.98 = 1047kPa
Litres to Gallons (Flow)
litres/min --> gallons/min
* litres/min x 0.2642 = gallons/min
eg. 40litres/min x 0.2642 = 10.568gallons/min
gallons/min --> litres/min
* gallons/min x 3.785 = litres/min
eg. 15gallons/min x 3.785 = 56.775
Kilometre to Miles
km --> mile
* km x 0.62 = mile
eg. 100km x 0.62 = 62miles
mile --> km
* mile x 1.61 = km
eg. 150miles x 1.61 = 241.5km
justdifferentials
Just Differentials
14
Sep 24, 2017 08:32 PM
Badfish740
Diesel Swaps
Dec 9, 2016 06:18 AM
alexcarey
Oct 14, 2015 06:05 PM
potatopants
Sep 15, 2015 06:26 AM
travisamorgan
Sep 2, 2015 01:00 PM
