Tool Time Discussions here pertain to the use of tools you use while fabbing and wrenching in the garage
miller 375 x-treme plasma cutter
Old Oct 15, 2006 | 06:43 PM
4runnermt's Avatar
Hey guys, I just ordered a miller 375 x-treme plasma cutter. Has anybody used one of these? If so, I'm curious what you think of this unit.
Old Oct 16, 2006 | 02:20 PM
NCSU-4runner's Avatar
thou shalt not covet thy neighbors plasma cutter
i dunno anything about the one you are getting but i've used a very small plasma cutter before and even it was a nice tool to have
Old Oct 16, 2006 | 03:32 PM
HarrisonP's Avatar
My dad has the Miller 625 at the house. I use it all the time and have to say that it is so much nicer than having to use a cutting wheel or torch. They do take some getting used to in order to make some nice cuts.
Old Oct 19, 2006 | 02:20 PM
yellowspeedracer's Avatar
That's the one I have. It's great for me but I don't have anything else to compare it to besides a gas-axe.
I got one of these to knock off the slag.
Old Feb 8, 2010 | 03:39 AM
glenyoshida's Avatar
Originally Posted by glenyoshida
Plasma cutter - expensive as heck and you still have to grind/clean up the edges with a grinder for a clean weld. Even if you could afford it there are plenty of other tools that you would get much more use from. I have one and rarely use it.
Acetylene cutting torch - crude cuts and again you have to clean up your edges with a grinder. It's very time consuming grinding the edges until they are clean and true.
Originally Posted by wyoming9
If you are getting poor cut quality from your Plasma and Oxy- Acetylene you are not doing it correct or need more practice .
If you did it all the time you would be able to get ready to weld pieces from both processes
Hiya Wyoming9, I'd rather be wrong and learn something than proud and ignorant. My Miller 375 x-treme plasma cutter only has two adjustments. The amperage dial and the on off switch. The air flow is regulated at 90 psi by the plasma cutter. I have an air/moisture filter to prevent water although the lines are normally dry anyhow. What exactly are you doing to make for a cleaner cut without contaminates? Are you using nitrogen something? Plasma is definitely cleaner than acetylene but it a long cry from a clean cut that an angle grinder with a cut off wheel will provide. When I cut A36 with my plasma I get cuts that are almost good enough to weld but there is still quite a bit of junk from the cut edge. Are you using MIG or TIG on your welds?
LosPatosDelSur
23
Mar 12, 2021 03:08 AM
skoti89
Apr 30, 2016 10:44 AM
HotNotch
Oct 8, 2015 06:51 AM
mdev126
Oct 4, 2015 04:48 AM
Bawlzdeep
Aug 2, 2015 08:35 PM
