Tool Time Discussions here pertain to the use of tools you use while fabbing and wrenching in the garage
Jig saw blades?
Old Apr 13, 2006 | 03:29 PM
vegaskurt's Avatar
Jig saw blades?
I need to get some blades that will cut 11ga steel and maybe some 3/16", any suggestions for what I should look for or brand recomendations?
Old Apr 15, 2006 | 01:53 PM
Poul D'eau's Avatar
I would recomend using a metal cutting blade in a circular saw. Much easier and quicker... That 3/16" steel will eat blades. If you got to cut curves see if you can get your hands on a cutting torch.
Old Apr 16, 2006 | 04:28 PM
vegaskurt's Avatar
I do need a torch....
I got some of the bosch metal blades and they cut nice straight lines in 1/8.
Old Apr 20, 2006 | 05:39 AM
maxpower_hd's Avatar
Any good quality blade works pretty well. The cheap or generic brands wear out almost instantly. Stay away from Harbor Freight for this type of thing. Get a contractor quality blade from the local building supply place. Bosch, Makita, Milwaulkee, etc.
Another cutting tool I use quite often is one of those air cut off tools. We call them wizzers for some reason. In Mass it's pronunced whizzah. In any event, they work great.
Old Apr 20, 2006 | 05:44 AM
shiftless89's Avatar
4.5" cutting wheel in my grinder very quickly dispatches mild steel
or if your dead set on the jigsaw do what maxpower hd said
okamikai
Apr 30, 2018 10:19 PM
reallynotamechanic
Sep 20, 2015 05:40 PM
markf1
Sep 3, 2015 01:23 AM
MonkeyElvis
Aug 4, 2003 04:39 PM
