Tool Time Discussions here pertain to the use of tools you use while fabbing and wrenching in the garage
Drilling metal
Old May 14, 2006 | 11:10 PM
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
Drilling metal
I have a plenty powerful drill with a nice set of metal drill bits but is there a trick to keep the bit from traveling around the metal? Sometimes I have the bit right where I want my pilot hole and as soon as I power the drill, it travels everywhere. Sometimes it isn't in a place where i can put enough pressure to keep it steady. Any tricks for this? Thanks!
Old May 14, 2006 | 11:13 PM
ChickenLover's Avatar
Use a center punch.
Old May 15, 2006 | 10:32 AM
snap-on's Avatar
start with a split point drill bit or something 1/8 or under as a pilot hole.
for thick steels your gonna need to step the holes up for best results. (1/2" hole should go something like center punch, 1/4-3/8-1/2)
Old May 15, 2006 | 10:43 AM
Bob_98SR5's Avatar
Originally Posted by ChickenLover
Use a center punch.
exactly and are you using that drilling oil stuff? the name escapes me right now. keeps the drill bit cool too
Old May 15, 2006 | 10:55 AM
Tacoclimber's Avatar
What he said, athough I can't remember the name off hand either...
Old May 15, 2006 | 02:17 PM
deathrunner's Avatar
The oil stuff is called cutting oil, right? That stuff definitely helps. Keep both hands on the drill and brace your arms against your ribcage, that kinda helps me keep things lined up.
I usually star larger holes with my trust 1/8" bit. I find step drill bits to be great for metal too.
Old May 16, 2006 | 07:38 AM
PirateFins's Avatar
Center punch is the way to go, split points are nice also. Cutting oil/tapping fluid keeps bits from getting dull. We also use "Tap Wax", it is a cutting wax that melts as the bit gets hot. Less mess, as the wax doesn't fling around like oil will, and the wax stays on the bit. Like death runner said "Step drill" bits make really good tools for doing large holes up to 3/4 inch with out having to change bits.
ashamsuddin
17
Jul 22, 2024 03:59 AM
gibbonsballer10
Oct 26, 2023 07:13 AM
Dale Johnston
11
Oct 31, 2015 10:22 PM
whiteyota93
Sep 29, 2015 02:31 PM
mdh
Sep 15, 2015 12:12 AM
