Tool Time Discussions here pertain to the use of tools you use while fabbing and wrenching in the garage
Anyone running hard shop airlines...copper...etc..?
Old Dec 13, 2013 | 12:44 PM
thebeeler's Avatar
Originally Posted by aztoyman
I put my 80 gal vertical tank Ingersoll-Rand compressor in a shed outside my garage so I don't have to listen to it. The outlet is halfway up the tank and a drain on bottom that I drain daily at least. I ran 3/4" copper from the compressor about 30' on a down slope to another drain.
I then had it turn 90 degrees into the wall of my garage and 90 degrees up the inside wall and at an upward angle towards the ceiling. It loops around the ceiling and then down to drains at the bottom of several down legs.
They make silencer intake filters to help keep noise down. Another way you can do it, is to just plumb your intake filter to the outside of the building. Almost all the noise comes from the intake filter.
I have run the pipes up off the main line too, it helps because any accumulated water won't just drop into the down pipes.
Old Jun 23, 2014 | 09:33 PM
loganroy's Avatar
Using galvanized pipe for my compressor zig zag up the wall to let water evaporate, drain plug down from top then to air hose
bigjstang
Jun 2, 2025 03:56 PM
icentropy
Sep 16, 2020 02:47 PM
skoti89
Jul 8, 2015 12:05 AM
skoti89
Jul 6, 2015 07:45 PM
bryan34w
Jul 6, 2015 05:53 PM
