Tool Time Discussions here pertain to the use of tools you use while fabbing and wrenching in the garage
air compressor reccomendation
Old Mar 1, 2010 | 11:48 AM
Ilovemountains's Avatar
Im looking for a new air compressor, I know I want at least a 15 gallon oil lubed pump, 120v preferably a stand up tank. Does anyone know anything about Harbor Freight Tools?
http://www.harborfreight.com/cpi/cta...emnumber=94667
I also found these locally as well:
http://www.tractorsupply.com/tools/a...l-lube-3300726
Id really like to find a belt drive but for all the more Im going to use it I dont want to spend the $$ for a new one, my price range is around $200 to $250, Ive been looking on CL for a used one with no luck too. Let me know what you think about the HF tools, they have a retail store outside of DC about an hour from me, I may run down there and pick one up if you guys dont think they are crap!
Old Mar 1, 2010 | 11:54 AM
One thing about the C. H. compressors are parts, I know I could buy a new piston for it in a few years if I need it, Ive never heard of the other company but the price and specs look great!
Old Mar 1, 2010 | 04:53 PM
Anyone??????? Im thinking the C.H. 15gallon tomorrow for usual home shop use but Id like to get some input!!!!!!
Old Mar 1, 2010 | 05:17 PM
CappyKD's Avatar
I have had awesome luck with the Harbor Freight stuff.
Old Mar 1, 2010 | 06:11 PM
heresjohnny's Avatar
i would only buy tools from harbor that i would only use once or twice, never anything that would get used every weekend for hours at a time. everything they sell is made in china so not much quality there.
when i bought my small compressor i read mixed reviews on the c/h as well
Old Mar 1, 2010 | 07:57 PM
dark_fairytales's Avatar
this is the HF compressor. it has worked great for me. vary reliable. i would buy another.
Old Mar 1, 2010 | 08:50 PM
I ended up buying one of the C.H. 15 gallon oil lubed compressors tonight...Its still in the box in my garage... Ive done a lot of reading over the last few days and hope its OK, the H.F. compressor looks great on paper, but I read a lot about them online this evening and was not impressed, the CH I know I can buy a new piston and ring for 6 years from now if need be,the nice thing about the oil lubed pumps is that if you maintain them, the technically should last for ever!! We shall see, I snagged mine for 180 + tax new in the box with a year warranty, Im not 100% sold on it yet because its still in the box I did check Lowes, Home Depot and Sears, none of theirs in this size are oil lubed, the last 2 Ive owned, one was a Sears, the other was a Task Force from Lowes, they both were maint free, and both wore out and would not build enough pressure to shut off after a summer of use, Ill admit, I ran the crap out of them from roofing to building the 2 story garage but in my opinion the oilless pumps dont hold up! Its a shame that the belt drive compressors are so expensive!
Old Mar 1, 2010 | 09:16 PM
mick cassidy's Avatar
well i did my homework on air compressors harbor freight is CHINESE FOR SUX
OK FOR STUFF YOU WILL use maybe a few times i had a heat gun catch fire a belt sander the motor smoked up a body hammer set the handle smashed and cracked i think a good air compressor will run you 500 to 1000 i use mine daily its my job and i actually built it from parts online i bought the pump from northern tool .com its a 10 hp 2 stage then i bought a tank and a 5 hp motor 1100 rpm and a square d pressure switch it took about a week to wire and set it up but man doesthis thing compress air
made a box to cover it so its quiet rubber pads so no shaking and its a 2 stage make 150 psi 10 years its been running daily chang the oil every 5 mos drain it weeky it cost me about $850 in parts not bad considering a 100 gal 2 stage will go for 2 grand !!
Old Mar 2, 2010 | 06:31 AM
Yeah, I looked at some of the 30 to 60 gallon belt drives but for a home shop I talked myself out of spending the extra $$, I run air ratches, impact guns, framing nailers, grease gun etc but only during projects not every day, I hope it holds up, it seems to be really well built, it has all copper lines from the iron compressor to the tank and switch, and a nice cooling fan, its a direct drive so its a little louder than a belt drive but it built 125 psi quick!!
Old Mar 2, 2010 | 07:00 AM
tc's Avatar
tc
Just remember the oil gets in the lines, so you need a filter/trap if you're going to be spraying paint, etc. (IMHO, this is actually a good thing for the tools you listed, as you don't have to worry about oiling them as much)
Old Mar 3, 2010 | 06:59 AM
Good call, Ill have to get an inline filter, I have a drier somewhere that I bought the last time I sprayed a car, that was years ago and I used my dads old school Craftsman 30gallon oil free, it did OK, he burned it up running one of my air grinders, it actually cooked the piston!!
mussy01
Dec 13, 2016 08:20 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
RatOmeter
Oct 22, 2015 03:17 PM
calderp
Jul 27, 2015 09:58 AM
skoti89
Jul 8, 2015 12:05 AM
