SE4RJ Action Thread
Old May 17, 2006 | 06:08 PM
  #201
waskillywabbit's Avatar
Originally Posted by dragr1
When will the SE4RJ forum be up and running-just curious, no pressure?
It is getting tested...just not "active" yet. I'll be SURE to let you guys know when the SE4RJ BBS is up and running. Look for it REAL soon.
Glad to see the picture gallery is getting filled up now and used!
Old May 17, 2006 | 06:11 PM
  #202
Originally Posted by Doc279
I had a weird exhaust tone after Tellico and a miss at idle while in gear
Tuned up the engine yesterday - new cap,plugs and wires - no luck.
Took it to the shop this morning - diagnostics showed bad #6 cylinder
compression test showed 90 lbs - all others 150 lbs. DAMN !!!!
I contacted Orient - they authorized a cylinder leak down test and we will go from there. I am 2 years into their 3 year warranty on the long block.
It may cost me some money but Orient seems like they will share the cost.
Could be a head gasket / burnt valve or a damaged ring & cylinder. No noise though and I didn't notice any loss of power.
Othe damage includes a broken sway bar (rear), dented gas tank, mashed rear bumper - again, tail pipe mashed - again and lots of mud and dirt.
We have the technology - we can build it better than before ! Thank god for some warranty. I hope.
Had a blast though !
You might remember Doc that I mentioned your rig sounded weird and that I thought it was missing when you drove up for the dinner/raffle Saturday night. Wabbit knows...Wabbit is wise.
I hope you get it fixed on their nickel...and soon!
Old May 17, 2006 | 06:12 PM
  #203
dragr1's Avatar
Start ordering off that list of parts that Monica approved!
Old May 17, 2006 | 06:20 PM
  #204
Doc279's Avatar
Monica is still talking about what a great time she had !
Ernie and Alison kept her tuned up with the Margarita's.
The parts list is on hold until I get this engine fixed. The 3.0 is living up
to the reputation. Just last week I was bragging on how well it has been running. The #6 cylinder is where the exhaust gases gather from the cross over pipe - Headers may be my next mod.
Old May 17, 2006 | 06:28 PM
  #205
ravencr's Avatar
Hope it works out Doc!
For those talking about the ledges, I've only driven up the far left, middle right and far right, leaving the far right as the main path that most people do.
I have climbed up the middle, but due to lack of breakover height I could never pull up and over it. I think if I had tried it after doing my drivetrain lift and flattening the undercarriage I could have been closer, but still don't know if it would have been enough.
Chris
Old May 17, 2006 | 06:35 PM
  #206
Stump1883's Avatar
Damage report for me is, a HUGE dent in my gas tank, prolly from being hung on it at Fains Ford. Also, dented the TJM pretty good, pushed the pass. side right into the body and bent a body panel or two. I also managed to put a good dent in the new BudBuilt skids, tore up the drivers side LTD cladding and the mystery noise that happens only when I put the truck in reverse, sounds like a driveshaft rattle or like it's hitting something, ah well, so is another weekend in Tellico....
Lets do it AGAIN.
Old May 17, 2006 | 06:40 PM
  #207
I think I got some dirt in my floor boards and a bungee chord scratched my door when I put the tarp on one night.
Old May 17, 2006 | 06:52 PM
  #208
ravencr's Avatar
It's amazing how much those trails change over the course of a year. This was from last year's run:
http://www.toyota-4runners.com/image...onslickrock.rm
Chris
Old May 17, 2006 | 06:54 PM
  #209
1985 4Runner's Avatar
You got dirtier that your truck Wabbit by fixing my rig...
THANK YOU! PM me & I'll replace the parts you used. I also owe somebody a birf, Will I think? I get names confused, sorry.
Notice how good that slider adapter looks on that Hi-Lift, go ahead & put me down for one Brian. I'll PM you.
I will have all my pics uploaded to the SE4RJ3 Gallery by tomorrow. Sorry, been a busy first of the week.
Old May 17, 2006 | 06:56 PM
  #210
ravencr's Avatar
Here's my ramp pics from last year Brett:
Chris
Old May 17, 2006 | 07:05 PM
  #211
Stump1883's Avatar
I never did understand how you got such a flexy rear axel Chris, it seemed like a pretty typical set-up. Those pics seem to compete pretty well with what I saw Brett's rig do this year, go figure.
  #212
Has anybody tried to use the FJ Trailteam ID card they were given to see the pics they took yet?
I go to the site & put my card # in, and it just redirects me back to the login. I guess they haven't got them posted yet.
  #213
dragr1's Avatar
Chris
Yeah, you definitely got higher, but I never could max out the rear suspension when backing up-the front maxed out before I got any higher. In the pics where I was backing, I'm no where near touching the bump stops on the rear.
Old May 17, 2006 | 07:08 PM
  #214
ravencr's Avatar
Scott, I think part of the reason is that I had stock coils front and rear with spacers, no OME stuff to make the springs stiffer and prevent the flex.
Brett, it sounds like you need to drop down in rear coil stiffness a tad, then maybe run some air shocks to compensate when towing, because it sounds like your current rear setup is much stiffer that the front, which is why you couldn't back up any further without lifting a wheel. Basically the weight of your truck wasn't enough to compensate for the stiffness difference between your front and rear setup, basically.
Chris
Old May 17, 2006 | 07:11 PM
  #215
dragr1's Avatar
Chris
Yeah, I know it, the cruiser coils would be great with airbags.
Andy-how hard are those airbags to install?
Old May 17, 2006 | 07:12 PM
  #216
Stump1883's Avatar
Good explination
  #217
ravencr's Avatar
Actually, he bought my airbags, but you might want to consider finding a right Monroe Air shock to replace your LC shocks of the same length or do the airbags that Andy has now.
Chris
Old May 17, 2006 | 07:16 PM
  #218
Originally Posted by 1985 4Runner
You got dirtier than your truck Wabbit by fixing my rig...
I was happy to help! And no need to worry about the parts...just a seal or two and some gaskets...no big deal. You do need to email me about the Factory Service Manual though. (I have my PM stuff turned off).
Will did give you the birf.
I worked on some slider adapters tonight as a matter of fact, as I'm a bit behind on filling orders due to SE4RJ3, but that's just wheeling.
That is a mighty fine shot of a slider adapter too!
Old May 17, 2006 | 07:17 PM
  #219
ravencr's Avatar
Here's two more videos of Slickrock from 4-10-04:
http://www.toyota-4runners.com/image...MOV00783-1.mpg
http://www.toyota-4runners.com/image...MOV00784-1.mpg
Every time is different, that's for sure1
Chris
Old May 17, 2006 | 07:21 PM
  #220
ravencr's Avatar
Here's the middle right line I was talking about:
http://www.toyota-4runners.com/image...MOV00639-1.mpg
http://www.toyota-4runners.com/image...MOV00640-1.mpg
http://www.toyota-4runners.com/image...MOV00641-1.mpg
http://www.toyota-4runners.com/image...MOV00642-1.mpg
Chris
