rear speakers not working with aftermarket H/U
i have a 92 4Runner that with the factory tape deck the rear speakers will work but they wont work with either of my aftermarket decks. Has anyone else had this problem or know how to fix it?
Guest
theres the seperate harness for the rear speakers. its a 4 pin harness. (actually has spots for like 6 or 8, ill get a pic for you in a few mins)
too bad you dont live here, id help as i JUST finished mine!
edit: heres the pic of what that harness looks like. this is the side that goes to your headunit wiring harness, it plugs into its match in the dash.
they work when i plug the factory deck back in (i used a factory adapter to install the other decks) but they wont work with my pioneer or jvc deck. im to the point i might just run wire straight from the deck to the speakers when i wire up my sub amp.
Yeah if i zero it i get sound just from the front and if i fade it all the way to the rear i get nothing. Edit: i guess i should add that this is the 23rd car i have installed a system in and i have never had this problem before. thats why its so frustrating.
Check this out. Each rear speaker has it's own little amp.
https://www.yotatech.com/forums/f96/rear-speaker-problem-55319/
You can also search "rear speakers" for more threads.
Look at page three, see note *1
http://personal.utulsa.edu/~nathan-b...11audiosys.pdf
Power: Terminal 2
Ground: Terminal 6
Sound: Terminals 1+ & 3-
Amp Turn on/off: Terminal 4
Power: Terminal 2
Ground: Terminal 6
https://www.yotatech.com/forums/showthread.php?t=55319
voiddweller
19
05-02-2016 09:10 PM
cchinny
06-25-2015 08:11 PM
