Stick Welding??? WTF???
#41
im an electric/electronic nerd too.. and i just got a lincoln 120 flux core... your standard beginner welder, but even people who weld everyday told me its good enough for most stuff you will encounter doing what WE do. some say a 220v for structre or really thick stuff... but anyways im going to start learning and practicing.
ive been collecting scraps from work and im gonna play with the settings and try and connect some pipe and other simple tasks..
before i try tacking some body patches..
anyone know any good total new websites for flux core 120v welding?
#42
Yes, electricity cost is not that high. You'll see 2-4KW draw with a typical 220V welder while it is running, so that is under 50 cents per hour for power. The killer with MIG is the consumables, I find between wire and shielding gas (Ar/CO2) you are looking at $20/hr. on that.
#43
I may be wrong on this but I was in the industrial supply a while back and I could swear I saw sticks that were labelled as being for aluminium welding.
#44
Yeah....I meant for the mig... I have yet to see a stick welder that requires gas. Before I got this mig I didnt even know they made flux core wire...it seems to work fine, although my machine is a 80 amp, so I doubt I could weld anything to thick, it only has adjustments for the wire speed, and a high/low switch for heat. I messed around trying to weld to stell rims together, and had to use the high setting.... it only took about 3 min to go all the way around the 15" rin, whereas the stick took me 3 min to get a 4" bead, and then had to change sticks... but that could all be settings...I'm still learning.
primordialbeast117
12-19-2015 12:23 PM
runnermedic
13
09-21-2015 05:20 PM
