My FJ40 Buildup
UPDATE!
Okay, time for an status update on what I've been up to. First things first, installed new mechanical fuel pump for the 350 v8, uses a push rod from the cam to pump fuel. Its more reliable than the electric, though I'll keep the electric for a trail spare:
#25
Installed transmission support brace from Advance Adapters, had to modify the brackets a bit so that I'd be able to remove the brace without too much trouble:
#26
Picked up new radiator from Cool Cruisers of Texas, 4-row, compared to the stock 3 row. I want to make sure I've got plenty of cooling power on the trail. Made a real fancy coolant reservoir, cost about a dollar:
#27
Installed a "transfer case saver" which is a safety precaution with the older style Landcruiser transfer cases, which have a split case design. This bracke helps to hold the two halves together:
#29
Common problem with the cruisers is the output shaft for the transfer case, that goes into the emergency brake drum has a seal that goes bad and leaks gear oil into the brake drum. Picked up a speedi sleeve that taps onto the shaft, increasing the diameter just a tinge to give a better fit with the TC seal. The seals on the front and rear TC output and the front and rear pinion were also changed while I was at it.
#31
So...went to reassemble the tc brake onto the tc, and realized that I wasn't going to have enough clearance between the drum and the crossmember that runs between the two frame rails. I had to spend some time with a cutting disk and an angle grinder to cut it off. Had a bit of steel lying around, was actually the old front bumper that I've been hacking pieces off as I need them. Got everything welded back into place, and the braces will serve as a mounting point for a skid plate, eventually...
#32
The finished product, plus a to-do list that is getting progressively smaller. Stay tuned for more next week.
#33
what has your budget been so far for this deal? it should come out to be a great truck... im continplating picking up a fj40, but the wifeasaurus would kill me
#34
Thanks Brian!
Hi Pat- bottom line, its an expensive endeavor to do right. Its all the little stuff that adds up, seals, fittings, etc. I bought the vehicle for ~3,000. I'm probably ~2,000 in parts, paint, etc, and still have a ways to go. They're old vehicles and require alot of TLC. However, they're relatively easy to work on, especially for a novice like myself. The body is pretty junky, so I don't even pretend that this is a restoration. My goal is make it look relatively good on the street, make it reliable both on and off road.
#37
this is just what i want to do this summer. your fj looks great!! the only thing holding me back is the fact that i am a collge kid and "another" vehicle is not needed, even though it is very very much wanted. keep up the good work!
