Vendor Advertising Vendor's, use this area to alert members to your OEM & Aftermarket Toyota parts
Universal 4 Link Suspension Kits from Barnes 4wd!
Old 07-07-2016, 04:21 PM
FormerVendor
Barnes 4wd's Avatar
Universal 4 Link Kits from Barnes 4WD!
All kits ship with brackets drilled to the correct bolt hole size and no extra cost!
This is the kit that has all the parts that we are always using in the shop for customers single triangulated four links suspensions. It is made to stand up to all the abuse that rock crawlers and weekend warriors put their rigs through, and everything else in between. It includes:
1 x Axle Link Mount Pair 0 Deg
1 x Truss Link Mount Brackets
1 x Frame Link Mount
1 x Adjustable Inner Frame Link Mount Pair 20 Deg
4 x Chromoly 1 1/4"- 12 X 1" Heim RH
4 x Chromoly 1 1/4"- 12 X 1" Heim LH
16 x High Misalignment Spacer - 1" to 9/16"
4 x 1-1/4" - 12 Jam Nut RH
4 x 1-1/4" - 12 Jam Nut LH
4 x Tube Insert (1-1/4-12) 1 1/2" ID Tube RH
4 x Tube Insert (1-1/4-12) 1 1/2" ID Tube LH
Add Grade 8 zinc plated hardware
We Also have Triangulated Lowers or Double triangulated 4 link kits!
Double Triangulated Four Link Suspension Kit 1 1/4" Chromoly Heims
Lower Triangulated Four Link Suspension Kit 1 1/4" Chromoly Heims
Enduro Joint 4 link kit
Old 07-09-2016, 07:39 AM
FormerVendor
Barnes 4wd's Avatar
We know the importance of a good articulated rig
Old 07-19-2016, 08:44 AM
FormerVendor
Barnes 4wd's Avatar
Another busy Tuesday, thanks Yota Tech!
Old 07-24-2016, 06:16 PM
FormerVendor
Barnes 4wd's Avatar
We only make parts that you can trust!
Old 08-05-2016, 06:00 AM
FormerVendor
Barnes 4wd's Avatar
We love staying busy! Thanks everyone!
Old 08-11-2016, 04:32 PM
FormerVendor
Barnes 4wd's Avatar
Friday is right around the corner!
Old 08-19-2016, 12:32 PM
FormerVendor
Barnes 4wd's Avatar
Another busy week in the books!
Old 08-26-2016, 11:37 AM
FormerVendor
Barnes 4wd's Avatar
Thank you for another busy week everyone!
Old 09-01-2016, 03:22 PM
FormerVendor
Barnes 4wd's Avatar
The weekend is almost here!
Old 09-13-2016, 04:06 PM
FormerVendor
Barnes 4wd's Avatar
Busy week thanks to you!
Old 09-20-2016, 03:52 PM
FormerVendor
Barnes 4wd's Avatar
Let's get those orders in!
Old 09-29-2016, 02:56 PM
FormerVendor
Barnes 4wd's Avatar
Get the parts you need at prices you can afford!
Old 10-07-2016, 11:41 AM
FormerVendor
Barnes 4wd's Avatar
Thanks for another busy week! We couldn't do it without you guys!
Old 10-26-2016, 07:24 AM
FormerVendor
Barnes 4wd's Avatar
We are running at full pace today!
Old 11-03-2016, 02:17 PM
FormerVendor
Barnes 4wd's Avatar
Old 11-15-2016, 02:12 PM
FormerVendor
Barnes 4wd's Avatar
Oh yes, you know you want it
