Warn M8000 vs. XD9000 Winches???
Old 10-24-2003, 04:57 PM
Tenkom's Avatar
I just wanted to say a thanks to all for the posts! Becasue the HS series winches won't fit in my TJM 17 bumber I think I will go with the M8000, they seem to be good value for the $! I think I will also invest the money in the synthetic cable, seems like a good safety thing to do, and makes handling the cable much easier on the hands too!
Also, like to see the fellow MN yototech'er on the web!
Ken
Old 10-24-2003, 05:08 PM
jx94148's Avatar
By what I see from Corey's pictures id that the XD has a longer drum that would hold more cable. Besides that they look very similar. Could it be that XD= Extra Drum? I= integrated solenoid that sticks up in the air.
I don't think you can fit much more than 100 of cable on an M 8000.
Old 10-24-2003, 06:05 PM
Flygtenstein's Avatar
And here I thought "i" series stood for "I can't fit it in my ARB."
I intend to add a HS 9500 at Christmas if Santa is cooperative. By the numbers, it only needs little over an inch on one side that I am having a hard time not finding on my ARB. People in the know who I have spoken to about this have said it is possible with a little adjustment. After using both HS and non-HS winches, making it work makes a lot of sense to me.
Old 10-24-2003, 08:25 PM
alanh's Avatar
I put a Warn HS9500 on my TJM T-15. Probably don't need the extra pulling power and I don't know that the extra speed is that big of a deal either, but the slightly lower current draw seemed like an advantage. I do have an issue with the clutch lever so I have to reach under and not through the hole they put in the top of the bumper. I'm not convinced that I wouldn't have had the same problem with the 9000 model though. I haven't seen the two models side-by-side in person, but from the drawings (not real good ones though) it looked like only the motor is a bit bigger and that didn't give me any problems.
Old 10-25-2003, 03:54 PM
  #25
m8000
Just thought I would add: I just put an m8000 in my arb bumper on my 92 pickup. I had an xd9000i on my last jeep and it worked well. Since I am broke and the lil' yota is pretty light I figured I could get away with the m8. After I ordered it I was afraid that I might be disappointed with it. Last week my father called me to winch his incapacitated tractor (real fullsize farm tractor) onto his trailer so he could take it to the shop. When the tractor started up the ramp, I looked over and realized that I was pulling the tractor, the trailer, and his full size GMC like it was a golf cart (single line pull). After chocking all of the wheels on the truck & trailer, the tractor pulled right on. I must say that I was very impressed and now that I bought a snatchblock, I'm not worried at all.
Old 10-25-2003, 03:57 PM
  #26
m8000
one more thing, if memory serves me correctly, the m8 has a 4.8hp motor and the 9000 has a 4.6hp motor. Gives me the idea that the m8 may last longer if used alot.
Old 01-29-2009, 06:55 AM
  #27
SilverSeven's Avatar
what do you guys think about the M8 for a new gen?
Old 01-29-2009, 12:58 PM
  #28
tc
tc's Avatar
Holy old thread revival batman! 4.5 yrs! :eek:
What do you mean by a "new gen"?
IMHO, an 8000 lb winch is too small for single line pulls on a heavy 4Runner. OK for a single cab, marginal for an extended cab. Plan on double line pulls all the time - which is going to cut the line speed in half and get aggravating.
Old 01-29-2009, 01:09 PM
  #29
1styota4X4's Avatar
not sure but atleast he searched
Old 02-11-2009, 04:03 PM
  #30
98 SNAKE EATER's Avatar
Go with a SuperWinch EP9.0 instead if you're really considering an M8K
The EP series has a much better clutch lever design, an external brake that won't melt synthetic line, a submersible Albright solenoid pack (best in the business) and a heavy duty 20,000 lb. snatchblock that's worth $100 bucks alone
It's also very comparable to the much more expensive Warn 9.5XP (they went head to head in Moab Jeeper's Winches in Hell article)
All for about the same price as an M8k (in fact, I think they're selling cheaper now)
Rick
Old 02-15-2009, 11:15 PM
  #31
vincentb's Avatar
Originally Posted by anthony1
One thing I've heard about those synthetic rope is that the heat from the winch motor can melt the rope. Dunno if that's a real problem or not....
Yeah, be careful of over heat.
ashamsuddin
17
01-13-2023 03:17 AM
justdifferentials
14
06-11-2017 08:36 PM
mxdw88
09-20-2015 03:13 AM
PureTacoma_Tundra
Vendor Advertising
09-06-2015 06:38 AM
AkitaDog
09-03-2015 09:01 PM
Quick Reply: Warn M8000 vs. XD9000 Winches???
