Tow Ball Hitch as Recovery Point?
Old 03-31-2005, 03:02 PM
ORB
ORB's Avatar
Is it safe to use one of these:
with a shackle as a recovery point? (It is rated at 6000 lbs while my hitch is rated at 5000 lbs)...
Old 03-31-2005, 03:07 PM
Flamedx4's Avatar
You mean put a shackle in it? Sure. But it might bend the clevis pin if it doesn't support it right, making it hard to remove. So use the biggest shackle that will fit.
Just never loop your recovery strap over the ball and yank. Seriously, ball failure is very rare - but disastrous if it happens.
Old 03-31-2005, 04:39 PM
ORB
ORB's Avatar
Right on...Thanks
Old 04-01-2005, 12:22 PM
Napoleon047's Avatar
another way is to stick the loop of the strap into the receiver hitch and put the pin through the loop.
Old 04-02-2005, 07:38 AM
CynicX's Avatar
There isnt a problem with using that. Its better then hooking onto the frame or something. I believe Warn makes a mount so you can hook a winch to a receiver. If you can winch from it, you should be able to pull from it...well considering thats what its designed to do ....I wouldnt pull more then its rated for of course....remember though, pulling a vehicle that is stuck in mud is gonna be ALOT more weight then the vehicle itself, since the tires will have a suction effect in the mud...
Old 04-02-2005, 07:55 AM
netwt12's Avatar
i welded a front tow hook from a 99 yukon to one and made a big bad tow hook. it works great.
Old 04-02-2005, 08:16 AM
4Crawler's Avatar
I used one of those with a 7/8" shackle for recovery use. I later made a long reach shackle receiver to replace it:
I can't use the std. short reach receiver in my bumper, the pin is set 5" back.
Old 04-02-2005, 04:38 PM
ORB
ORB's Avatar
That's awesome! I wish I had crazy fabrication skills .
4x4-runner
04-18-2017 09:08 PM
Peevedkitten
11
08-31-2015 06:57 PM
dropzone
08-11-2015 05:16 PM
defrag4
07-31-2015 10:50 AM
pyramid
07-30-2015 10:05 AM
Quick Reply: Tow Ball Hitch as Recovery Point?
