OBA , with compressor and tank questions
OBA , with compressor and tank build / questions
I`m wondering what size tanks people are running, and why.
Also if you put it together yourself what compressor did you use.
EDIT2: also is it possible to run an engine driven compressor without sacrificing my AC?
EDIT:
I currently have a 2.5 gal or a 8"x40" tank i could use and was looking at VIare compressors, wondering what has worked for you folks...
some good info for any one wanting to do this to a second gen here
http://www.tacomaworld.com/forum/2nd...board-air.html
EDIT:
As long as you have room for it, run as big a tank as you can:
- http://www.4crawler.com/4x4/CheapTri...tml#HowMuchAir
And yes, you'll need to fab up a custom bracket to mount an engine driven compressor with the stock A/C in place.
TURBOrunnerNM
07-22-2015 11:01 AM
skoti89
07-08-2015 12:05 AM
