Where can I find these headlights?
Originally posted by OneTrickToy
Does anyone have a part number for the APC housings? I was looking online at CSK Auto but I can't search the headlights without putting in vehicle information. And my vehicle info only pulls up the sealed beams.
http://www.performancestyleattitude....headlights.htm
last 2 rectangular ones...
Originally posted by ldivinag
look at the bottom:
look at the bottom:
I'll have to see if any of my local CSK shops have them in stock... What about wiring? I can't remember if the sealed beams use the same connector. I guess I'll just pop the hood and see what I've got.
#25
yes it uses the factory connector. You just have to pull your grille and headlight bezels, unplug the old halogens.
Isert new bulbs into APC housings, drop the clip down, put on the rubber boot and plug it into the factory wiring plug. Put the bezels back on and replace the grille.
Voila all done and it's a lot brighter out at night now.
#29
they are a replacement for any vehicle that uses the halogen sealed beam headlights. They are a direct fit and plug into the factory harness. All you need is an H4 bulb.
09-04-2015 09:27 AM
HookahRoo
07-20-2015 07:06 PM
scottyg486
07-19-2015 05:34 PM
rushw
07-18-2015 01:46 PM
icentropy
07-14-2015 10:23 AM
