Timing belt on '00 4Runner SR5?
Old 06-12-2006, 02:41 PM
stangman39's Avatar
Hi all,
Looks like I'm finaling a deal on a '00 4Runner SR5 off Ebay. Silver, sunroof, running board, trailer hitch, cloth interior. I think I'm getting a pretty good deal on it...I've been having a hard time finding ones for a decent price w/under 100K miles.
It is at a dealer. Has about 80K miles on it. They don't know for sure if the timing belt has been changed yet or not. I assume this is something I should have done soon regardless for piece of mind, right!?
I'm having the dealer it is at get me a quote to change the belt and am also gonna call around some local places near me. It is currently in TX and I'm looking to have it hauled to me in GA.
What is a good or avg. price to have this work done?
Thanks,
Mike
Old 06-12-2006, 02:44 PM
Crux's Avatar
General practice is @90k for $250
Old 06-12-2006, 02:51 PM
stangman39's Avatar
Cool...thanks. That is much cheaper then I had expected!
Mike
Old 06-12-2006, 02:54 PM
Bob_98SR5's Avatar
usually when they do the timing belt, they change out all the belts + water pump + thermostat. mine was a little over $500 about 2 yrs back
Old 06-12-2006, 03:17 PM
ebelen1's Avatar
Ditto. Since they've pulled everything apart, you might as well change the water pump so you don't incur additional labor down the road. I would question doing the timing belt at 80k miles as there are many here that wait much longer. You will have a non-interference motor so you don't run the risk of ruining your motor if the belt brakes. Just a thought.
Old 06-12-2006, 03:59 PM
Bob_98SR5's Avatar
if they are paying for it, have it done.
Old 06-12-2006, 05:44 PM
stangman39's Avatar
Nope...I'll be paying for it. It wasn't worked into the price of the vehicle.
If it is a non interference motor and most wait till at least 90K I'll wait then.
Thanks,
Mike
Old 06-12-2006, 08:20 PM
youngbuck's Avatar
I was told that Toyota recommends changing all of this:
timing belt (of course)
water pump
drive belts
thermostat
tensioner
idler
camshaft seals
crank shaft seal
Might seem a bit excessive, but for peace of mind and to do the best job possible, maybe?
Opinions?
Old 06-13-2006, 09:47 PM
Ringmaster's Avatar
It's on my list of "Things to do" too. Timing belt, upper idler, tensioner, H20 pump, Thermo, and the 3 drive belts.
Old 06-14-2006, 03:58 AM
MTL_4runner's Avatar
That is for just changing the belt only (ie belt + labor).
It will be closer to $500 if you do the WP and thermostat too.
This list above is an exhaustive list and would certainly be comprehensive but in most cases at 90k miles it is unnecessary. This subject has been covered in quite a few threads, but I myself, at 90k would just do the belt and flush the cooling system (radiator, engine block and heater core) then refill with Toyota red coolant to keep the WP in good condition.
Old 06-14-2006, 06:09 AM
Rick F.'s Avatar
Location: Far western Kentucky (transplanted from central PA)
I agree with this caveat:
Since I tow frequently, I now tend to do the entire recommended list every 90-100k miles to my 3.4L. Prior to that when I had my 3.0L (with a 60k mile frequency), I would do the water pump every other belt replacement. Although it MAY be overkill, the additional approx. $250 over a 4 year period ( I drive about 25k/year) is worth my peace-of-mind.
Old 06-14-2006, 07:02 AM
You can't argue with that.
Old 06-14-2006, 08:20 AM
Ringmaster's Avatar
Just curious, what doe's the Toyota "Red" antifreeze/coolant have that helps out the water pump?
Old 06-14-2006, 11:17 AM
I know it is info overload, but if you really want to know all about coolants, here's THE thread for that:
https://www.yotatech.com/forums/f2/just-finished-timing-belt-coolant-question-77747/
Old 06-14-2006, 11:19 AM
Ringmaster's Avatar
Thank's for the link! You da man!
voiddweller
19
05-02-2016 09:10 PM
vasinvictor
01-20-2016 12:39 PM
layifioren
10
07-06-2015 02:26 PM
marcusSRG
06-27-2015 07:13 AM
infinityisfive
06-16-2015 06:51 PM
Quick Reply: Timing belt on '00 4Runner SR5?
