Sticker Removal
Old 04-02-2004, 08:54 PM
Senior Member
data's Avatar
Sticker Removal
Yeah I've searched So I guess the best way is to do the blow dryer trick eh? I have a very, very, very tough sticker that needs to be removed from my back glass. I tried it last night with just a straight razor, but no luck....
Old 04-02-2004, 09:02 PM
Tacoma Dude's Avatar
Time to get rid of the Dukakis for President in '88, huh?
EDIT:
I vouch for the WD-40 too
Old 04-02-2004, 09:13 PM
doink's Avatar
if you can ge tthe graphic off..but still have a sticky residue...put goo gone on it , let it sit, then get a credit card and it scrapes away fairly easy.
Old 04-02-2004, 09:47 PM
Jboy's Avatar
For leftover gooey stuff, body or glass, I use WD-40 and a rag. Works wonders.
Old 04-02-2004, 09:48 PM
SoCal4Running's Avatar
Ive used everthing from carb cleaner to wd40 with sucess. Usually it will soften up the glue so the razor can remove it.
Old 04-03-2004, 02:54 AM
shovelhead's Avatar
Believe it or not (brush on type) Easy Off Oven Cleaner for glass or paint as long as the vehicle still has the factory paint
Old 04-03-2004, 05:42 AM
waskillywabbit's Avatar
Talking Goo gone
Goo gone works fine on glass, but on paint plan on repolishing and waxing as it takes off the polish/wax and leaves the area dull, but not really a big deal. It took the junk left behind when I swapped my emlbems to black pearls off with ease. Just spray it on, wait a while, spray on some more, wait a while and then come back and it will practically fall off. Just wipe off the excess so it doesn't run onto your paint and you have to polish/wax it.
Old 04-03-2004, 06:19 AM
mike_d's Avatar
as everyone else said here, goo gone is pretty good. however, i did have one sticker on my truck that wouldn't come off with goo gone and a razor blade. actually what worked for me is a chisel that i found in my tool box. it was brand new, so it had a really nice sharp flat edge. the key was that i was able to put a good amount of force on the chisel to scrape the sticker off. with a razor blade you can't seem to put enough force on it to get the sticker to budge.
Old 04-03-2004, 06:48 AM
I used to have a little handle that you can slip a regular razor blade into it and use as a scraper it it might have been snap-on? It worked very well.
Old 04-03-2004, 06:56 AM
newheeler's Avatar
I've used wallpaper remover to soften stickers up before. I'd also recommend getting one of those 4" blade scrapers with a big handle.
Old 04-03-2004, 07:43 AM
Senior Member
data's Avatar
Welp with a little wd-40 and a razor blade, the stickers came right off with ease. Thanks guys
Old 04-04-2004, 07:45 PM
jzdoit2's Avatar
Ive tried them all. THe best one that worked for me was the 3M adhesive remover. Took a little elbow grease but it took all my factory stickers off with no problems. As soon as I get a pic Ill post it up.
1uzRunner
63
11-10-2018 03:58 PM
LotOMiles
09-14-2015 11:45 PM
Rickstwowheels
09-09-2015 06:12 PM
FJtoyman
09-08-2015 04:47 AM
gp66
09-07-2015 08:29 AM
Quick Reply: Sticker Removal
