Pinging when engine warm
Old 08-08-2005, 11:24 AM
GaryBee's Avatar
My 92 4-runner v6 3.0 runs smooth at start up but it reaches normal running temp there is a pinging noise at 3000 rpm or greater. Changing fuel doesn't seem to change it. Does anyone have any ideas what might be causing the problem?
Old 08-08-2005, 11:36 AM
rimpainter.com's Avatar
When you say "3000 RPM or greater" you did not mention if that was under load (driving) or at idle. Which is it?
Old 08-08-2005, 11:58 AM
GaryBee's Avatar
The pinging can be heard even when stopped and just revving .... It also occurs during driving but doesn't seem to matter if climbing a hill or on a flat section
Old 08-08-2005, 12:02 PM
I would look for something loose on the rotating assembly then. The idler pulley is of particular interest here. Shut the motor down and check for play in everything you can, such as the PS pump pulley, AC compressor pulley, etc.
This doesn't sound like detonation to me since it is happening while sitting there and revving it too (rarely does that happen unless your timing is completely whacked out).
Old 08-08-2005, 12:06 PM
Unhappy99's Avatar
Check fuel injection pressure at the rail. If its low, you are running lean, which will ping. Then the question is, 'why is the pressure low'? Not many things to go wrong here: Fuel pump, regulator, filter.
Old 08-08-2005, 03:29 PM
Ironmike4x4's Avatar
I'm very impressed unhappy.... diagnostic skills at its finest. Ever thought about working as a mechanic?
Old 08-09-2005, 05:44 AM
Unhappy99's Avatar
I take shadetree mechanicing one step farther and work entirely in the dark.
Sleaker
08-26-2020 06:03 AM
RaginAsian91
Engine Swaps
03-30-2019 09:17 AM
Seattle_Sign_Guy
07-12-2015 12:38 PM
Jonny246
07-12-2015 04:51 AM
Kluch8651
07-09-2015 10:39 AM
Quick Reply: Pinging when engine warm
