My truck dies when i turn my lights on.
Yes thats what I originally tried. My fuse looks good, I have got the battery and alternator tested, tightened and greased the battery terminals, and looked for broken or missing grounds and vacuum lines as well. Now I'm clueless where else to look? Thanks for replying.
Seems a lot of people forget, Electric grease is non conductive it's not going to fix anything it's a protective coating prevents oxidation and arcing. You scrubbed those connectors to bright shiny metal?
"looks good" and "is good" are not interchangeable, you need to measure voltage.
Even a wire that reads low on resistance may be too corroded/ too thin to carry the current. Measuring voltage bet one end of that suspect wire and the other end under load would reveal this.
O.P., Pls see my post on how to check a fuse. Same would apply to checking a suspect wire.
Aleeex_u
06-05-2016 06:52 PM
WTB[International]: 93 P/u fuel door lock, roll bar, hitch, chrome rear bumper
Gamble_STi
06-27-2015 07:54 PM
sharrack
06-26-2015 09:33 AM
