My truck dies when i turn my lights on.
Old 03-01-2017, 12:50 PM
Co_94_PU's Avatar
Originally Posted by Daryl Peterson
Yes thats what I originally tried. My fuse looks good, I have got the battery and alternator tested, tightened and greased the battery terminals, and looked for broken or missing grounds and vacuum lines as well. Now I'm clueless where else to look? Thanks for replying.
"looks good" and "is good" are not interchangeable, you need to measure voltage.
Seems a lot of people forget, Electric grease is non conductive it's not going to fix anything it's a protective coating prevents oxidation and arcing. You scrubbed those connectors to bright shiny metal?
Old 03-02-2017, 07:53 AM
RAD4Runner's Avatar
Second that^^^!
Even a wire that reads low on resistance may be too corroded/ too thin to carry the current. Measuring voltage bet one end of that suspect wire and the other end under load would reveal this.
O.P., Pls see my post on how to check a fuse. Same would apply to checking a suspect wire.
Old 03-03-2017, 04:07 PM
ZUK
ZUK's Avatar
I have the same issue. did anyone find the cure to this original post?
Daryl-
What kind of meter readings did you get ?
eng off
engine idling
engine with parking lights on
with heater blower motor on
driving lights on
gillesdetrail
11-19-2019 12:56 PM
Aleeex_u
06-05-2016 06:52 PM
rbravo1
06-29-2015 01:34 PM
Gamble_STi
06-27-2015 07:54 PM
sharrack
06-26-2015 09:33 AM
Quick Reply: My truck dies when i turn my lights on.
