looking for a 200amp alternator?
Originally posted by amusement
If someone has a chance, could they explain the need for the extra battery wired in serial? Thanks.
If you read his post, even though he says series. he meant parallel. He's using the term series as adding a second battery to the system. A common mistake that people make.......
2 batts with 24 volts is like the minimum.
yes you are right parallel. And as for this hand dcab you daym straight this is a powerful hand. This hand held oon to the back of my truck and prevent it from fallin into the deeap and dark ditch
SCZIG
09-20-2015 09:00 AM
