lifting my runner
Adding an aftermarket bumber/winch shouldn't be a problem with an added 1" body lift. My only concern has been the famous 4Runner rear sag, fixable with the performance products progressive rear springs.
You are wrong about the body lift/bumper thing, you aren't going to only install a body lift on the front to make it "look" level, you need to suspension lift the front to "actually" level the vehicle: I'm not talking about the bumper not fitting. I'm talking that if you have a spacer lift front an rear and add all the weight in front the front will sit lower and the rear will stay. (nose down). If you were to have and adjustable coilover you could just adjust more lift to the front to make up for the weight up front causing the nose down, impossible with the spacers and a body lift has no bearing on this and cannot fix the nose down. there are numerous threads here at yotatech that talk about this.
I see what you're saying Keisur. I own a '96 so rear sag is a concern for me. If a full body lift was to be installed in order to insure that proper clearence was available for the tires due to the added wieght of a bumper/winch, what other problems besides visual would having the nose down produce? I guess the skid plate/tranny/engine would still be lower. Am I getting the idea now? Ya, I think I'm getting the picture.
#26
Originally posted by shiftMX
keisur, i didn't think i had to do a differential drop on a 2wd?
#27
Haha j/k, I saw everybody doing it in the other thread, I thought it'd be fun over here. And it is A LOT of fun!!
#28
Originally posted by Toyo_Runner96
it's ok, Keisur's just gettin old.........
He must be getting senile as that is TWO slips in one day...
#29
Originally posted by waskillywabbit
Rob,
Rob,
#31
34!! holy crap that's like 15 years older than me! Almost double my age!!!!!
#32
http://home.houston.rr.com/keisur/ARB_RD90.pdf
06-01-2021 01:51 PM
Jnkml
07-06-2015 01:20 PM
Vargntucson
07-04-2015 12:15 PM
