Gear Install - Pattern Check
Old 06-04-2014, 04:16 PM
herdnerd's Avatar
I would appreciate those with more knowledge looking at these patterns on 4.88's in a 01 Tacoma non ELD rear. I never thought to check the thickness of the factory pinion spacer. I did not add anything to it.
Pinion PL 12+ lbs, no spacer
Backlash 0.010 If I swap the ring and case side shims it drops to 0.004 which is too tight, correct? Could I add some pinion shim to tighten it up or would I risk pushing the pattern too deep?
Thanks in advance!
Drive:
Coast:
Old 06-05-2014, 03:40 PM
herdnerd's Avatar
I sent the pics above to ECGS. They thought pinion was too deep so I took out the stock pinion spacer and threw in all the shims that were sent with the install kit. That totaled to about .072 down from stock at .081. I swapped the ring and case side shims and ended up with BL about 0.0075.
New pattern
Drive:
Coast:
Same setup, pattern in a different spot
Drive:
Coast:
Old 06-05-2014, 05:37 PM
Fossilized
Staff
dropzone's Avatar
might check a few pattern's on Zuk's site: http://gearinstalls.com/
for comparison
Old 06-05-2014, 06:58 PM
herdnerd's Avatar
I've spent quite a bit of time on that site.
Old 06-07-2014, 02:34 PM
ZUK
ZUK's Avatar
Your 1st set of patterns at the beginning looked great.
Old 06-09-2014, 12:37 PM
herdnerd's Avatar
Thanks Zuk. And thanks for all the info you've posted on your site.
I went back to my original pinion depth but had to leave town for a week so I'll get back to it this weekend. I was able to tighten backlash to 0.007 and get the solid spacer shimmed to get pinion preload to 12 or so. i will post some new pics this weekend.
Old 06-13-2014, 08:22 AM
herdnerd's Avatar
This is where I ended up going back to the stock spacer (0.811) and getting backlash to 0.007. It seems a little deeper than what I had originally.
Drive:
Coast:
smthwsn357
12-04-2023 02:08 AM
bigjstang
08-25-2021 12:41 AM
mskalmus
05-28-2017 07:51 AM
jerusry
10-19-2015 05:28 PM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: Gear Install - Pattern Check
