E-Locker Mod Trouble Shooting
#29
you guys are great it works now :bigclap: ... no thanks to the crappy writeup now when someone has the same problem they well find there answer
#36
elton, maybe you nuked it! in his write up, #4 states
"Give yourself 2 or 3 inches of slack on that wire FROM the white harness, just in case. Cut the wire and bring out the soldering gun. Tape off the wire hanging down from nowhere. Solder the wire coming out of the white harnass to an extension wire, which you will be grounding."
the pic below shows how you should of done it! Slow down next time you free mod grubbin @$#%$
non the less, glad you got it fixed...finally! maybe if you made a write up that clearly states the correct way to wire the box, bob will put it on his site and in the off road enhancements
#38
sigh....."Solder the wire coming out of the white harnass to an extension wire, which you will be grounding."
geez!!!
maybe yuo aer bettre of raeding liek this. i bet yuo were drniking!
geez!!!
#40
well since you werent drinking, these guys are having a sale!
http://eyeglassworld.imswebmktg2.com...que/88730.php?
