Which Clutch Pedal Spring?
I want to replace the clutch pedal spring in my 98.
The clutch squeaks and also the pedal doesn't come up all the way each time and I have to pull up the pedal manually in order for cruise control to engage.
I was wondering if you guys have a part # or a specific spring I should purchase to change this out with?
Thank you!
Thank you!
#70 true value spring
Thank you!
Thank you!
okay I will try to find the previous threads and look for a # 70 spring.
I don't want to stiffen the clutch pedal for daily driving but want it to pop all the way up for cruise to work normally.
It will not stiffen your pedal. All that spring does is pull it up the extra 1/2" that your master cylinder doesn't do. More than likely...one or more of your cheap plastic bushings in your torsion spring is broke and that's what's causing the issue. Junk the torsion spring and buy yourself a #70 spring at true value or get a brake pedal return spring from Toyota... Same thing.
so buying a new spring from Toyota wont solve the issue? I purchased one but have not yet tried to install it. Is there any way to replace the plastic bushings and fix it that way or no? I have yet to take a look at it and would like to have the correct parts when I start thanks.
If it is a brake return spring, it will work. I had my master and slave cylinder both replaced and the pedal was still not coming completely back. It squeaked and the pedal rattled going down the road. I ripped out the torsion spring and the bushings came out in pieces which was the issue. Replaced with a return spring and its peace and quiet....and now extends all the way back.
It is not the huge big spring that will last forever it is the cheap plastic bushings that fail.
I am sure you can replace those bushing and have a few months to a year before you need to replace them again.
You could have some bronze bushings machined but me being cheap I went with a free spring off my parts truck.
I'll be doing the #70 spring next go-round:
https://www.yotatech.com/forums/f2/fixed-stupid-plastic-clutch-pedal-bushing-19137/
At 205,xxx I replaced both the stupid mega spring, stupid stinking bushings and the clutch pedal too, because both had a lot of wear:
New and old parts comparison:
The spring
The Clutch Pedal
The spring
The Clutch Pedal
okay I gotcha now, I need to return the clutch spring and get a break return spring or 70 spring from true value. thanks guys
I can say that in 10 manual cars Ive had Ive never had this happen but at least its cheap to fix!
he's gone
7
12-03-2019 07:08 AM
justdifferentials
Just Differentials
14
09-24-2017 08:32 PM
Shaun Crystal Gomban
07-30-2015 10:13 PM
