Bad Transfercase???? (videos)
Old 03-20-2012, 06:42 PM
Dirty_725's Avatar
ok i thought i was having problems with u-joints as this started slowly and faintly.. now it is very loud and i have had to stop driving my daily. i thought it was the double cardan joint in the drive line. took it out to press in some new ones and just thought i would see if my noise was still there, and wouldn't you know it, it was. metal slaping sound coming from the output shaft of T-case. at one time this only happened while in 2wd, you could shift into 4wd and the noise would go away. T-case chain slapping as it stretches or what.. this rig never gets wheeled. driven maybe 100 miles a week.
don't know if my sig is filled out..
1997 x-cab tacoma 33x12.50 tires, 5 speed 2.7L
http://www.youtube.com/watch?v=PYm4z...YawvPlzNwLYE1I=
http://www.youtube.com/watch?v=ovSpw...ature=youtu.be
Old 03-21-2012, 01:50 AM
aowRS's Avatar
How many miles on the truck? Have you ever changed the transfer case fluid?
Andreas
Old 03-21-2012, 04:41 AM
AssYriaNrocKer's Avatar
Subscribed....I'm having a similar issue with my reverse gear. I'm pretty sure the noise is coming from the t case as well. I removed the shaft to check u joints and they where fine. 235k on truck and fluid was changed about 4 months ago. Here's a video of the sound. 4 wheel drive with no drive shaft.
http://www.youtube.com/watch?v=-v5Dd...2&feature=plcp
-RONI-
Old 03-21-2012, 02:20 PM
Dirty_725's Avatar
My truck just turned 71000. I don't think I can remember changing the fluid.
That is how my noise started. Just a ticking like a u-joint at low speed then progressively got worse.y ukoints were bad and the centering ball in the cv joint as well.
Old 03-21-2012, 03:50 PM
Black_1985_SR5's Avatar
Mine made a similar noise when it went tits up check your fluid and see if there are metal shavings or a burnt smell
Old 04-11-2012, 09:43 PM
Dirty_725's Avatar
ok gotta bump this to the top....
going to pick up the new t-case in the morning and the drive shaft should be done by the end of the week... any other suggestions on the problem before i pull this thing out and replace???
Old 04-23-2012, 05:32 AM
Mine turned out to be a broken tooth in the tgransmissions reverse gear. Good luck with the t case swap hope it works.
-RONI-
JNapolitano
11-14-2019 07:46 PM
Jcrawl94
10
10-24-2015 04:34 PM
_Nicco_
08-28-2015 07:26 PM
Shaun Crystal Gomban
08-02-2015 08:00 PM
mlavery85
07-12-2015 10:33 AM
Quick Reply: Bad Transfercase???? (videos)
