Advice on coil spring compressors
Guest
i used to rent from autozone, but i just bought a set of craftsman ones, they are great, even though they dont technically fit the tundra springs.
i had a set of harbor freight ones nearly explode on me, DO NOT BUY THEM!!!
dont buy chinese crap!
as for using a vise, i didnt, i used sand bags or carpet or foam under the spring. i dont care about scratching them up though.
honestly, with quality tools, its not scary at all. man up and just do it.
I always grease the threads on them also. It'll keep you from shredding them if you do use an impact gun. If the springs are heavier I would just take them to someone with a heavy duty compressor. Cheap, safe and easy.
#25
Let me ask the question a little different. If all you are going to do is compress the OEM springs enough to remove the shock and replace it - then what would you recognize. I think this would require less force than new springs
#26
This is a link for the safest and best you could use!
http://www.nationaltoolwarehouse.com...qx/product.htm
#27
#29
#30
terminator
07-27-2015 07:13 PM
skoti89
07-08-2015 12:05 AM
Vargntucson
07-04-2015 12:15 PM
