95 Tacoma throttle problem
2.4 L automatic when the truck sits or is cold I hit accelerator and the truck takes right off, when warmed up the peddle feels stuck, I have to push it harder than usual to get it going. I sprayed wd 40 on th throttle body and it works for a couple days then it feels hung up again.It does not happen ll the time.
Any ideas??
thanks
Any ideas??
thanks
Sounds like the throttle body. I assume when you said sprayed WD-40 on it, you were talking about the (cable) outside of the throttle body. If that is the case, try cleaning the throttle body on the inside and see if that helps it.
http://www.4x4wire.com/toyota/mainte...throttle_body/
Seattle_Sign_Guy
07-12-2015 12:38 PM
Poncho0206
07-10-2015 06:21 PM
