1990 4Runner starting trouble
I have a 1990 4runner V6 4wheel drive with about 180,000 miles on it. Recently changed out the plugs, wires, rotor, and cap and it's run just fine (idles a little high when cold, but that's not the problem) After letting it sit for a day I went out and it wouldn't start (had been running fine when I turned it off) I changed out the Coil and the Ignition Module and still it wouldn't start. Had it towed to a mechanic and when it got there it started right up. The mechanic said he thinks it may be the Fuel pump going out and wants about $600.00 to replace it. I've found the part for about $110.00, but have never done this. Does this sound like it may be the problem and if so how hard is it to do?
