130 amp alternator
130 amp alternator
Installing an electric fan on my 2000 Tacoma 2.7 truck- Also upgrading to a 130 amp alternator- any recommendations and do I even need a HO Alternator?
I am installing a Spal electric fan (30101516) (12- 13 amp draw) thanks!
Pray tell why do you feel you need a electric fan??
Every one that I ever touched got removed and thrown away
Now I can understand if you have a swap and don`t have the room for the factory set up
What kind of electric draw do you have ??
4x4 sound system ??
Do lots of winching work ??
4x4 sound system ??
You don't think that that 12-13amp load puts any parasitic draw on your less than 100% efficient alternator???
There ain't no free lunch.
I'll go for factory engineered reliability every time.
A properly operating factory fan clutch largely mitigates parasitic draw when the air temps thru the radiator are moderate.
I have a Spal electric fan on my 90 Mustang- no issues but I did upgrade to a 130 amp alternator- fox body Mustangs
have always had electrical issues with a stock alternator! I installed this Spal fan well over 17 years ago! Do you guys
think a stock Toyota/Denso alternator can handle an electric fan? I think the Toyota stock alternator puts out up to
80 amps?
80 amps?
Assuming that you go with the electric fan, I would install an on/off switch in the cab as you would be able to shut the fan down during a water crossing: it's the only benefit that I see in using elcetric verses stock fan. If you have multiple minor mods to the truck to make available more HP, it might contribute to slightly more power but it would be likely unnoticeable on it's own. As for the alternator, if you already have it, it can't hurt.
Yes- that is how I have my Mustang set up with an electric fan! No issues at all!
Not too concerned with water crossings- only time that happens is if we have a big rain storm and some streets flood!!
Southern Florida is very flat!
Or you are in the mud in the everglades!!!
87tyota77
04-22-2020 07:00 AM
